02-05-2009, 02:24 AM   #1
gr8wings's Avatar
Macro Extension Tubes
Macro Extension Tubes:
I'd like to bay a set of Macro Extension Tubes
How do they work with a pentax-M 50 mm and how with DA series lens ?
02-05-2009, 03:11 AM   #2
QuoteOriginally posted by gr8wings Quote
Buy one and try it out. It's the best way to learn
Regards Emil
ps/ I have heard that it works quite well...but save the money and buy a real macro if you looking for quality
02-05-2009, 04:12 AM   #3
QuoteOriginally posted by losecontrol Quote
Regards Emil
and then use the tubes with the macro for extra extra close ... much greater than 1:1 but at a cost of DOF ... this is where you get into stacking images with software like Combine ZM
02-05-2009, 06:24 AM   #4
Wheatfield's Avatar
They'll work fine with the M50mm Macro, but your DA lenses don't have an aperture ring, and I haven't seen a set of tubes with electric contact pass throughs. If the tube isn't passing information from camera to lens, your DA lenses won't have aperture control.
02-05-2009, 09:49 AM   #5
codiac2600's Avatar
Kenko makes a set that has all the contacts. Runs about $150-$175 depending on where you look. Nice set.
Remember with extension tubes there is a rule to figure your ratio. If you have a 50mm lens you need 50mm of extension to get 1:1 so you'll need to attach all three tubes to get super close or the largest and next size down to get 1:1.
You'll love them!
02-06-2009, 04:31 AM   #6
gr8wings's Avatar
Thanks for your precious support.
I think I'll try a cheap set of macro tubes.
02-06-2009, 05:50 AM   #7
I don't understand how you can lose quality with tubes compared to a genuine macro lens. Would someone please explain that?
- Andrew
02-06-2009, 08:45 AM   #8
kibipod's Avatar
Pentax tube set
I have original Pentax extension tube set (3 different sizes). They work fine with M and F glass. Autofocus does not work for the AF lenses. My DA lens is not compatible with the macro tube set though. I bought the set from ebay ~$50.
02-06-2009, 08:45 AM   #9
codiac2600's Avatar
QuoteOriginally posted by AndrewShirley Quote
- Andrew
Technically you don't lose quality but you do lose light gathering capability since the added tubes take away from the lenses natural fstop.
You won't be able to beat the quality of most macro lenses as they little to no distortion and usually have a better lens characteristic. Plus the distance you have to be to get 1:1 is much greater giving you an advantage when hunting skittish creatures.
02-06-2009, 09:13 AM   #10
Wheatfield's Avatar
QuoteOriginally posted by codiac2600 Quote
Actually, technically you do lose quality if you move the lens out of it's design parameter. This is the case when you mount a lens that is not corrected for macro work onto a set of tubes or a bellows.
Practically, there may be no loss of quality, but technically there may very well be.
02-06-2009, 09:37 AM   #11
codiac2600's Avatar
You aren't changing the lenses design like you do with teleconverters which add glass, but the addition of air has such little impact on IQ if any that it's negligible.
It's an unmeasurable thing as we can't compare the 50mm at a target to a 50mm lens with tubes at the same target since we lost infinite focus. What most people believe is quality loss with bellows is shake transfered through the whole system which is amplified by the distance the lens is away from the sensor plane. Honestly is there is IQ loss you couldn't measure it with the naked eye because there is nothing to compare it too.
02-06-2009, 11:34 AM   #12
Thanks Chris, for explaining my gut feeling
- Andrew
02-06-2009, 01:43 PM   #13
Blue's Avatar
You'll love them!
Remember there is a different formula used when using a 50mm macro lens than when using a nonMacro lens.
02-06-2009, 02:11 PM   #14
Mike.P's Avatar
I got a set of Panagor macro tubes (has electrical contacts for aperture) with a Pentax-F 50mm f1.7 a few weeks ago for the equivalent of $50.
Although not as good as my macro lenses they do a pretty good job.
This was taken with all 3 tubes attached to a Pentax F* 300mm f4.5
camera, extension, macro, pentax help, photography, tubes
Question about using extension tubes for macro uchinakuri Pentax SLR Lens Discussion 17 06-09-2010 03:00 PM
Macro Cheapo Macro Extension Tubes JimD_K10D Post Your Photos! 3 09-26-2009 04:55 PM
Macro Extension Tubes fccwpe Troubleshooting and Beginner Help 7 07-04-2009 09:07 AM
Macro Extension Tubes Rondec Troubleshooting and Beginner Help 8 04-13-2009 09:40 AM
1:1 Macro with extension tubes hinman Pentax SLR Lens Discussion 10 07-29-2008 02:50 PM
All times are GMT -7. The time now is 09:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
