Originally posted by detlef a) Take pic in RAW
b) Convert RAW to Jpeg
c) edit Jpeg, crop etc
d) print some nice ones to hang on the wall 8x10. I print a fair number of them to rotate my pictures and also burn the odd CD for relatives
The reason I want to take shots in RAW is so I can always go back and work with them as I learn a bit more. I want to learn to convert to b/w, maybe even try HDR or infrared. But I need to go step by step and get the basics down pat first.
OK, seems you want the first part-the RAW part of the older workflow material. Great; I'm thinking that you have a folder of RAW files on your harddrive and you've done enough archiving type stuff to meet your needs.
Let me modify your vision a bit:
a) Take photos saving files in sRGB tagged RAW
+JPEG,
a1) copy JPEGs to CD,
a2) have a commercial lab process these JPEGs to 4 by 6 inch prints,
b) Convert RAW to editor native RGB files,
c) Edit native RGB files; crop etc,
c1) save RGBs as good quality sRGB tagged JPEGs sized to 300ppi,
d) Have the nicer ones commercially printed at 8x10 to hang on the wall.
The most obvious change is the commercial printing. Color management is a very complicated affair; tagging, converting, pre-viewing, blah, blah , blah. Things that you should avoid until you get the basics firmly understood. You need the initial 4 by 6s to have a point of reference-a proof image.
RAW is also very complicated--more than can be done successfully in a forum environment. Google Bruce Fraser, CreativePro, and Out of Gamut. Bruce passed on a short while back, but he left a legacy of material that stands as the industry standard. You might want his book on RAW:
Camera Raw. Don't worry about the industrial stuff in the title, it's written at an average user level. Might want to grab his book on sharpening too:
Real World Sharpening; you will need it relatively soon!
There are three distinct methodologies when it come to digital processing:
1) get it right in camera and then group images by lighting conditions and batch process them via visual corrections.
2) get it right in camera and then group images by lighting conditions and batch process them via calibrated camera RAW.
3) shoot it, fix it in photoshop.
Scott Kelby champions the basic material for the first two methods; He's the NAPP President and his book:
Amazon.com: The Photoshop CS2 Book for Digital Photographers (Voices That Matter): Books: Scott Kelby is the reference.
Dan Margulis follows method 3 ( and his guiding intent is to produce images for reproduction in books magazines and newspapers). His book:
Amazon.com: Professional Photoshop: The Classic Guide to Color Correction (5th Edition): Books: Dan Margulis is the standard reference---very advanced!
You might also want to see the foundation document covering Photoshop workflow; it;s here:
Primer, and here:
PS workflow. This stuff is a little dated, biased toward photoshop and rather stuffy. There are newer emulations by other authors out on the web--Google "workflow". I've used the fundamental ideas in a number of programs: Photoshop, GIMP, PictureWindow Pro, Elements...
Try to remember that the saleman who sold you on digital as
economical was a liar--Time-wise and dollar-wise it's very expensive!
