Originally posted by xecutech It's been over a year since I visited the forums. I have to admit that I put the camera up for a while. I got it out this past week to rekindle my desire to shoot better pics, and I still have trouble. My pics always look dark, but it could be the lighting in my home.
I am going to try to find a local class or photography club to get better.
Hmmmm - well, first off, a class would be a great way to get to know your camera and learn more about photography. I took a year of photography in high school, and still don't really know much about it (I learn a ton on this forum though). In fact when out of my element, I still suck too
. A club might be good but I can't say because A- I've never been in a photography club (there isn't one around here), and B- I've never liked clubs, they always seem to break into some sort of power-structure/dominance contest rather than being about whatever it is they purport to be interested in...but I digress.
I've now made two starts on explaining exposure in this post, and it is a big can of worms, and redundant as I'm sure it's already explained better somewhere out there on the internet, so I'm gonna give you a checklist to follow to see a way to adjust the brightness of your photos. (I don't really know your experience level so bear with me if I sound like I'm being condescending - I'm not...)
- Set the mode dial to Av (aperture priority)
- Set the ISO to auto and use the rear e-dial to set the auto ISO range so it starts at 100 and goes as high as the K10D goes (at least 1600) - so now on the ISO menu page you should have a green bar extending from 100 to 1600+ - hit OK to return to picture taking readiness.
- Use the rear e-dial to set your aperture to the most wide open setting (turn the dial till the top LCD displays the smallest F number ie. F3.5)
- Press and hold the EV compensation button (labeled with a +/-) and check what the top LCD shows - use the front e-dial (it's the front on the K20D, so I'm guessing it's the front for you too) to set EV compensation to 0 for now.
- Take a picture
- Now press and hold the EV compensation button and turn the appropriate e-dial to set the EV compensation to +0.3 or +0.5
- Take another picture
- Now set EV comp. to +1.0
- Etc...
Each of those photos should be progressively brighter, and you can pick an EV compensation setting which gets you the look you'd like. You'll probably want to set multi-segment or center-weighted metering as spot metering will give very varied results unless used carefully. If it's
really dark in your house, Av mode should still give you properly exposed photos but the shutter speeds might get too long to take pictures hand held but that's unlikely.
