02-15-2009, 05:19 PM   #1
Freezing cold and its effects on camera.
Living in Northern Ontario we frequently get sub zero temperatures in the winter and especially in January where it recently went to - 44C.
At this temperature there are photo opportunities believe it or not.
My question is:
Do these temperatures affect the CCD or the LCD of my K100D. That is crack or damage them internally due to the extreme freezing temperatures?
I am aware of the affects of cold on the batteries and the procedure of a gradual cooling/warming procedure when exiting and entering a building with the camera.
Any thoughts or experience on this matter would be appreciated.
02-15-2009, 06:11 PM   #2
navcom's Avatar
QuoteOriginally posted by sylvanite Quote
My question is:
You should be fine. I have taken my K10D and K20D out in -25F temps several times this year. Your only concern is condensation. Just make sure when you come indoors you let your gear warm up for abot 15 minutes before taking out the memory card or changing lenses. When coming inside, condensation builds up on the cold surfaces from the warmer, more humid air around it.
There is another thread on this forum that talks about sending a K10D into space on a balloon. If these cameras can handle that, I don't think you have anything to worry about.
02-15-2009, 06:41 PM   #3
Ratmagiclady's Avatar
The general consensus would seem to be that it's not as big a worry as some might think: just keep your batteries in mind, and let the camera warm up in a bag before exposing it to warm room air, (a good general rule is by the time *you're* used to being in out of the cold, your camera's probably OK condensationwise. )
I'd imagine a frozen camera's case and parts might be more brittle if subjected to shocks or anything: -44 is pretty extreme, of course, but people in general seem to have fewer difficulties than you'd expect.
02-15-2009, 09:12 PM   #4
Jewelltrail's Avatar
sylvanite Freezing cold and its effects on camera.
My question is:
sylvanite: I would read through the thread below--it should allay any fears or concerns you have on this topic. Best!
https://www.pentaxforums.com/forums/general-pentax-photography/43671-winter-s...-possible.html
02-16-2009, 07:25 AM   #5
Thanks to everyone who replied.
It has relieved me of a nagging worry.
Now I can shoot with more confidence in the cold.
Thanks Jewelltrail - I read the thread.
02-16-2009, 07:35 AM   #6
Jodokast96's Avatar
I didn't have any time to read through the linked thread to see if it was mentioned there, but as the temps drop really low, isn't there a possibility of the seals shrinking enough to compromise the camera?
02-16-2009, 08:10 AM   #7
Good news, frozen camera = half the noise!
I'm not even kidding, ice cold shooting at ISO3200 is a blast, the cleanest images you will ever see!
Also fantastic for long exposures.
02-16-2009, 08:34 AM   #8
kurt's Avatar
QuoteOriginally posted by IsaacEastgate Quote
Yes, the thermal noise is doubling for every 6 to 8 degrees Celsius, which also means that when you go down in temperature, you'll get far less noise
02-16-2009, 09:29 AM   #9
reeftool's Avatar
I have used my K10D in below 0 f temps without problems. It handles the cold much better than I do. I worry about my camera more in summer heat. I recently noticed the low noise in the cold benefit while shooting an outside hockey game with a 200 mm recently. I set my ISO up to 1600 to get the shutter speed I needed and I was really surprised how sharp and clear they were. I had to double check my exif.
02-16-2009, 06:27 PM   #10
Arpe's Avatar
All I can say is HOLY CRAP that's cold.
02-17-2009, 12:21 PM   #11
AndrewG NY's Avatar
I noticed recently that temperature is recorded in the EXIF (viewed with exiftool). I've been meaning to go back and look at what was recorded there on some colder days.
camera, pentax help, photography, procedure, temperatures
K-x Freezing :( zach Pentax DSLR Discussion 3 08-19-2010 02:09 PM
Cold, cold batteries = headache (help?) nnyorkie Pentax Camera and Field Accessories 15 02-07-2010 12:11 PM
Hi from freezing Houston samper Welcomes and Introductions 3 02-01-2010 11:09 AM
Camera in the cold oatman911 Pentax DSLR Discussion 9 12-16-2008 12:34 PM
K100D Freezing up? FotoPete Pentax DSLR Discussion 4 09-22-2007 11:26 PM
All times are GMT -7. The time now is 07:07 PM. | See also: NikonForums.com, part of our network of photo forums!
