Originally posted by Jet Now I started to think about ND grads. I understood the Cokin filters aren't the best ones, you can get - but Lee ones are pretty expensive for me. Finally I decided to go for Hitech ones from Formatt - they should be decent quality for reasonable price. (Any thoughts?) I don't want to go for screw-in grad filters.
The Hitech filters are very good quality and a very reasonable choice - much better than Cokin.
Originally posted by Jet But what I actually need to ask is: I would like to use the polariser + the ND grad in the same time. Is it actually possible?
It is possible, sometimes helpful but always tedious.
Originally posted by Jet I would like to use these filters on DA Ltd lenses (35mm, 70mm and upcoming 15mm one) - won't there be a problem with the lens hood?
Can I mount the polariser on the lens, than attach the square filter holder, operate the polariser for the effect I want and finally put the ND Grad on it's place... I never did it so could you let me know about some sort of BEST PRACTICE?
Or just how to operate polariser + ND Grad in the same time? In efficient and fast way?
If you use the separate polarizer your suggested useage is fine, though somnewhat tedious. I would also suggest to either use the Cokin wide-angle filter holder or simply cut down one standard holder, because using the polarizer and the filter holder on top increases the chance of vignetting.
Another option is to use a polarizer which fits into the round filter slot in the Cokin holder. But the original Cokin is not overwhelmingly good (some contrast loss and a slight colour tint). The Kood polarizer (fits the Cokin holder) is not really much better, perhaps a little bit less tint. There is, I think, a Lee polarizer which fits the Cokin holder, but its excessively expensive. So this last option, being more convenient, affords some compromising.
Ben
