Originally posted by Sean Nelson This is pure speculation, but it's possible that you caught an intermediate number as the camera was enumerating the card's file system and calculating the remaining capacity.
Or he was simply shooting RAW at that point, hence the lower number. When he switched back to JPG, the frame counter "shot through the roof", as they say.
To see just how many shots you can take with your current settings, go into your K200D's menu and select the field where you can change resolution. Activate that field and a four-digit frame counter should activate in one of the corners of the screen. It should change the moment you change the setting to something else.
(this advice is based on my experience with the K100D. Since the two cameras are related, I expect similar results, but do not take my word for it. If the camera does not display any frame counter, it might be by design)
