03-01-2009, 06:01 PM   #1
Step up rings and lens hood
I am thinking about getting a cpl, size 77mm, for my Tamron 28-75mm. The lens has a 67mm filter thread, so I need a step up ring (67mm to 77mm). If I decide to use the step up ring and the 77mm filter, does that impair the attachment and use of the lens hood? I do not want to buy separate multi-coated cpls for each lens unless necessary. Any help would be appreciated.
03-01-2009, 07:35 PM   #2
heatherslightbox's Avatar
Unless you have another lens that takes a 77mm filter, why would you want buy such a big filter? If 67mm is the largest filter size out of all the lenses you have, then why not just get a 67mm CPL and buy step up rings for any smaller lenses you may have (??-->67mm)?
HTH,
Heather
03-01-2009, 07:50 PM   #3
Ratmagiclady's Avatar
Yeah, very likely it would preclude using the stock hood. If you don't also have a 77 thread lens, or plan to have one, it's good to avoid that. One thing you *can* do, though, is have a dedicated hood to fit the polarizer, (and the widest lens it'll be used on) if you'll be swapping it around.
03-02-2009, 04:42 AM   #4
My eventual lens road map will include at least one lens (DA 12-24mm F4) that has a 77mm filter thread. If I decide to use step up rings, I would use the larger size filter on similar-sized lenses (i.e., not use the 77mm filter on a 49mm filter-accepting lens).
My guess was the step up filter would block the addition of the lens hood.
67mm, 77mm, camera, filter, hood, lens, pentax help, photography, step, step up rings
General rule for step-up step-down rings? uchinakuri Pentax SLR Lens Discussion 2 06-18-2010 09:54 PM
New PL + Lens Hood or Step-Up Ring? Tomzee93 Pentax SLR Lens Discussion 1 05-16-2010 09:29 PM
step-up or step-down rings? ncrecordkeeper Pentax Camera and Field Accessories 8 05-13-2010 07:31 AM
filter step up rings or filters for every lens? opiet70 Pentax SLR Lens Discussion 6 12-25-2009 02:20 PM
Step-up rings MrTea Pentax Camera and Field Accessories 3 05-26-2008 12:43 PM
All times are GMT -7. The time now is 01:54 PM. | See also: NikonForums.com, part of our network of photo forums!
