03-06-2009, 08:50 PM   #16
heavensSinner's Avatar
Update -_-
Just found out that the light meter doesn't work anymore. (Maybe cause there was a battery left in there for over 15 years??)
03-06-2009, 10:45 PM   #17
Just1MoreDave's Avatar
Obviously a new battery needs to make good contact with the camera. Corrosion of the terminals or the battery cover is the most likely culprit. You can also check the second most likely culprit yourself. Take off the bottom cover (three visible screws) and see if there is still a wire attached to the battery compartment. It may have corroded off.
03-07-2009, 05:56 AM   #18
If the battery contact on the bottom of the camera is no longer shiny, rub at it with a pencil eraser. The eraser will remove the corrosion/oxidation/whatever and ensure good contact.
Also, for the lens, any sort of glasses cleaner fluid and/or cleaning cloth will be great. They're already made for cleaning coated optics anyway!
camera, k1000, pentax, pentax help, photography
Which ($<30) tripod will hold Pentax K-x and 55-300mm lens? RUSBoris Pentax Camera and Field Accessories 15 10-18-2010 11:05 AM
About the screws that hold the Pentax K-x together crocowhile Pentax DSLR Discussion 15 04-17-2010 04:09 AM
Pentax SLR lens - Good for Pentax D-SLR? mychen Troubleshooting and Beginner Help 16 12-31-2009 09:42 AM
Suggestion Change name of Film SLR and/or SLR Lens sub-forums clawhammer Site Suggestions and Help 4 07-31-2008 06:55 AM
Pentax Gallery "On Hold" tag wmmk Photographic Technique 9 04-20-2007 03:32 PM
All times are GMT -7. The time now is 12:11 AM. | See also: NikonForums.com, part of our network of photo forums!
