Originally posted by andie80 I just got my k200d and so far I am confused about its perfomance. The shutter never seems to go below 0,3 seconds (isnt it supposed to be able to go down to 1/6000 of a second?) and as most modes have a way of compensating for other things by means of adjusting the shutter images come out blurry even on a bright afternoon. I am beginning to feel as though I bought a copy! I see no improvement, thus, when using the image stabilization.
Maybe it should be there but I also hear a strange humming sound from the camera as the shutter is activated. For long exposures it's there throughout the duration of it.
In the evening and in total darkness my k200d is pretty much out performed all the time by my 5 year old compact.
What settings can I tweak with to boost things up?
The humming is shake reduction working. Shake
reduction means that, in equivalent conditions, you may shoot 1/30 s, instead of 1/60 s, and get the same sharpness. BTW, without a tripod, you want to shoot at least 1/(focal length) s shutter speed to prevent blur. If you shoot around 1 s, use a tripod and shoot with 2s mirror lockup (mirror slap causes vibrations in SLRs).
As for your problem, you may want to increase ISO speed. By default K200D's auto-ISO goes to 400, but you may increase it. To get a more predictable behavior out of your camera, set the auto-exposure to center weighted, focus point to central, use Av mode and read the fine manual.
