Originally posted by naughty.smurf
thankyou Erik for your help, I still cant get the pk lens to work, changed over to manual but just keeps flashing up with an f--- inside and everything is shut down. I maybe have a camera that doesnt accept these manual only lenses. This i was told is a possibility. thankyou for your help and advice it is very much appreciated to a newcomer. I always used fuji s5600 and s6500 cameras before so this is a complete change but the pictures are so different, best wishes, Russ.
If this is an autofocus (AF) lens, then you may have moved the AF setting on the lens when you mounted it. Look where the lens meets up with the front of the camera.
If it is a manual focus (MF) lens, you have to go into the camera menu and enable Aperture Ring.
You did get a manual with the camera didn't you?
