03-17-2009, 04:35 PM   #1
Should I return K20D - purple line in all pics
A few days back I noticed that some shots had a vertical line of purple running thru the picture everytime I zoomed into the picture in playback mode. Today I saw that every single shot taken has a purple vertical line (even without zooming in). I have heard of purple banding issues in pentax cameras. Is there anyway that this can be fixed or should I return the camera and get a replacement and hope that the other one is a good piece? I have attached a picture to show the vertical line. Experts please weigh in with your opinion.
Last edited by mccarvindh; 03-17-2009 at 04:37 PM. Reason: did not upload pic on first try
03-17-2009, 04:45 PM   #2
I had some bad vertical banding the other night and from time to time I'll get some sort of bizarre lines, but they've been horizontal and it's been very, very, very, rare--maybe one out of every 800 pics (which doesn't really concern me). If every shot you're taking is like that, I would get a new camera ASAP.
03-17-2009, 05:29 PM   #3
SpecialK's Avatar
I would send it in for service but do not expect a new camera. They are allowed to fix things.
03-17-2009, 06:14 PM   #4
vagrant10's Avatar
I think I've heard of this happening several times before and the users replaced the sd card and the problem went away. Worth a shot anyway since it's easy and takes little to no time to try...
03-17-2009, 06:35 PM   #5
Igilligan
Guest
If its new...
Try that SD card fix that vagrant suggested, if that does not work take it back, if its more than 30 days out of the store, send it in for service. They are usually fairly fast.
03-17-2009, 07:55 PM   #6
Damn Brit
Guest
It is more than likely the card, this has been talked about several times in the past, it would be highly unusual if the camera were at fault.
03-17-2009, 10:21 PM   #7
I had lines in some photos once on my K10D. After reformatting the card a few times the lines went away.
03-18-2009, 06:18 AM   #8
Thank you all very much for your suggestions. I tried reformatting and even changing the card, the line wouldnt go. It is not even 10 days since I purchased - so I think I can return this.
I will ask for a replacement and hope that my ill luck does not follow me around like a faithful dog!
Thanks everyone.
camera, line, pentax help, photography, picture, return
K20D leaves a line on the right side of photo. ? Craig66 Pentax DSLR Discussion 16 12-02-2010 07:00 AM
K20D pic vertical line problem oceandeep Pentax DSLR Discussion 5 04-16-2010 10:24 AM
Pics in a park by K20D+DA*50-135mm (Many PICS) dsport Post Your Photos! 2 10-18-2008 10:51 PM
K20D and the Tamron 70-300 - Has the Purple Monster been slain? Entropy Pentax SLR Lens Discussion 11 05-28-2008 12:41 AM
Anyone who switched to K20D from Canon's Line? augustmoon Pentax DSLR Discussion 18 04-08-2008 05:38 PM
All times are GMT -7. The time now is 06:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
