03-21-2009, 08:56 PM   #1
UV filter as protector lens?
I just got a B+W CPL filter for my DA* 16~50mm lens and the filter is little bit of expensive, so can I screw another UV filter for my CPL filter as a protector lens?
Thanks!
03-21-2009, 09:06 PM   #2
Moderator Emeritus
Do you mean put a UV on top of the CPL? I wouldn't recommend that even if you got a very good one. A few reasons. You'll need a very good one to keep the image quality and that could cost as much as the CPL so why bother. No matter how good the filter is, you're adding a lot of glass to the front and adding the chance of reflections and image quality loss. Finally stacking 2 filters on a wide lens like this will most likely vignette at wider shooting angles.
Don't bother and just keep the hood on to protect the lens and filter.
03-21-2009, 09:11 PM   #3
I got your messages. Thanks and have a nice weekend.
03-22-2009, 07:44 AM   #4
I'd keep the CPL in its case, and put a nice Hoya UV or Skylight filter on the lens.
Unless you use the CPL a lot, it's best to keep it off, as you'll lose light with it on.
03-22-2009, 11:03 AM   #5
OregonJim's Avatar
This is one of those topics that has been debated for years (I remember some BBS threads about it back in the early '80s!).
Here's what I do:
Use a medium quality UV filter as a lens cap.
Take the filter off to take photos - if a once-in-a-lifetime shot appears, leave filter on - no wasted seconds to remove the lens cap.
Even a high quality filter can noticibly reduce image contrast due to lens flare. Stacking filters will cause vignetting and further contrast reduction. If you must use a filter (such as the CPL), also consider using a lens hood, or at the very least, shading the front of your lens with a hand or hat.
It's understandable to want to protect your investment, but you have to balance that against image quality. Only you can decide what is best for you.
03-22-2009, 04:38 PM   #6
Ira
Using filters for lens protection works nominally.
1) A scratch here and then ain't gonna kill the lens, and you won't get those scratches if you're semi-careful.
2) If you're ripped or trip on a rock, the filter won't protect the lens anyway.
3) UV/haze/skylight filters don't add anything to your image, they take away. More of a gimmick to me.
03-22-2009, 07:25 PM   #7
roentarre's Avatar
Personally, I would whack B+W filter on for the sake of protection of front element. You never know what would happen.
However, a CPL filter on top of B+W filter is not recommended. The result would be severe degradation of colour in the image, accentuation of the shadows in the image and causing vignetting as a problem.
03-22-2009, 07:32 PM   #8
More importantly, though (and especially on lenses with metal filter rings) a filter protects the filter ring from getting dented.
Trust me on this.
03-25-2009, 10:06 AM   #9
QuoteOriginally posted by lithos Quote
Trust me on this.
Amen to that!
I have a 28-105mm with a Hoya UV filter that has a dent on it. If the filter hadn't been there then it would have been the front of the lens damaged. So it worked out for me....
camera, cpl, filter, lens, pentax help, photography, protector, uv, uv filter
Hoya HD Protector Filter 58mm DaniRo Ask B&H Photo! 4 06-21-2010 07:47 AM
Hoya HD Protector Filter 58mm DaniRo Pentax SLR Lens Discussion 5 06-18-2010 09:42 PM
Filter/protector suggestions Jasvox Pentax SLR Lens Discussion 7 12-16-2008 01:13 PM
UV filter or Clear Protector dazman Pentax Camera and Field Accessories 12 05-29-2008 05:15 PM
UV filter vs Protector Snowcat Pentax SLR Lens Discussion 7 12-12-2007 10:17 AM
All times are GMT -7. The time now is 12:08 PM. | See also: NikonForums.com, part of our network of photo forums!
