Originally posted by ytterbium I think it varies because then you'd get more accurate or jumpy WB in difficult/changing light. Like one image yellow, one correct (if the actual WB is near threshold).
When shooting RAW and examing the files in a RAW processing program, they definitely reports lots of different values, not just a few "preset" values, and I'm assuming that's true for JPEG too. So I'm betting you're right.
Quote: What is with all those people suggesting RAW. Sometimes it is so unneeded. ~5 times file size, slower camera operation, additional conversion required, harder for pc to process (browse, copy, store). If one asks for WB, he has a reason not to use RAW.
5 times larger? Maybe for the cameras that don't compress the RAW files, but not for the models produced the last few years. As for the additional conversion, it's not required if you are using most modern software. You only need to convert to another format if you plan to share the images with others - but 9 times out of 10, you'd want to resize them anyhow, so it's not really an *extra* step. And also, many modern RAW workflow applications make RAW *easier* to deal with than JPEG, since everything with RAW is always non-destructive. Of course, some (like Lightroom) will also provide non-destructive operations on JPEG files too, making them as easy to work with as RAW. But the only time RAW is harder to work with than JPEG is when using old-fashioned software like PPL.
Anyhow, not to say anyone - particularly a "beginner" - needs to shoot in RAW to get good results, or to feel good about themselves as photographers. I just want to point out that with the right workflow and software to support it, RAW really does not complicate things the way you imply here.
