Originally posted by johngs Thanks Venturi,
I just checked and I can get foam core here easily enough.
Just to confirm ... is the piece of foam core and the matt both the same size?
and .. so the matt is glued to the foam core with the phot in between/
and .. do you usually attach some kidn of wire or string to the back for hanging?
Many thanks for your advice. i found it very helpful.
Yep. For example, say you have an 8x10 or 8x12 print you want to mount. The "typical" size mounting is 11x14. So, your mat and foam board would be 11"x14", and the mat would have a 7-3/4" by 11-3/4" opening.
Lightly (don't soak it!) spray an even film of the adhesive to the full surface of the foamcore board. Mount the photo onto the board, using the guide markers you made
before applying the adhesive, and then mount the mat on top, lining up the corners/edges carefully before applying
any pressure.
NOTE: This adhesive stuff has an interesting curing process. Anything you stick to it in the first 30 seconds is PERMANENTLY BONDED to it. But if you wait a minute or two, it works a bit like reusable stickum - you can peel and replace
to a degree.
