04-03-2009, 04:20 PM   #1
esman7's Avatar
Spot metering - can I select?
Hi,
I purchased a K200d a few months ago and let me tell you... I love it!
I'm trying out new capabilities and I'm new to the whole photography thing. I just learned about spot metering vs. matrix metering; however, I was wondering what the deal is and how I can use it to my benefit.
I love using the Av feature and I am trying to get more creative shots. I hear that spot metering usually rests on the center of the photo; however, I use the manual focus points ALL THE TIME.
If you switch to spot metering, will the spot be determined by what your focus point is on or just always be the center?
Thanks for helping a noob!
04-03-2009, 05:30 PM   #2
RBellavance's Avatar
Unfortunately no. The spot meter is always in the center, no matter which focus point you select.
04-03-2009, 05:55 PM   #3
khardur's Avatar
as RBellavance said, no.
But using the multi-segment metering, you can set custom function [5] to Link the AF point and the AE metering. It doesn't explain it in great detail, but this I assume will give more weight to the focus point you've selected, which is similar to what you are talking about, with more or less accuracy depending on the situation, as using the center spot meter presents a different set of challenges.
04-03-2009, 06:42 PM   #4
aleonx3's Avatar
QuoteOriginally posted by khardur Quote
Yes, this is the setting you may want if you want the metering to give more weigh to the focus-point. However, I usually turn this off because it is very easy to get metering incorrectly when the metering mode is set to multi-segment (for example, if the focus point is either in the dark or bright area).
04-04-2009, 05:50 AM   #5
mattdm's Avatar
I've e-mailed Pentax customer service about this, and their response is that it actually does spot metering at the selected point — not weighted.
I find it annoying that the custom setting doesn't, therefore, change the functionality of the spot meter dial setting — that way, you could use center spot-metering simply by putting the focus spot in the center. As it is, if you're using the center focus sensor, the two settings on the metering dial are exactly the same, which is silly.
04-04-2009, 07:56 AM   #6
QuoteOriginally posted by mattdm Quote
I'll have to do more controlled testing, but I use that setting enabled (link AE to AF point) with selectable AF points, and it certainly does not feel like the camera is spot-metering on the selected point, but more like it biases matrix metering towards the selected point.
04-04-2009, 10:19 AM   #7
mattdm's Avatar
QuoteOriginally posted by RBellavance Quote
I'd be interested in seeing your controlled testing. I exchanged several e-mails on this exact point and they were quite certain. (But they've been wrong before.) And I don't have the attention span for controlled testing myself.
04-04-2009, 10:48 AM   #8
khardur's Avatar
Well, whether it's spot metering or not, it's still the closest to what esman7 is looking for.
Awww now you're all making me think about doing some testing, since it's entirely crappy out today.
-Dan
04-04-2009, 09:10 PM   #9
Spot metering with AE-L might be the better option for any of the automated modes. I use spot metering when using high ISO settings to ensure the subject is exposed well and have never found the linking option to work as well for this.
04-04-2009, 09:53 PM   #10
octavmandru's Avatar
I just tested this and it seems the meter will bias the exposure in towards the focusing point.
what is 0,5 sec for spot metering is 1/8 s for the linked option.
I personally prefer to spot meter all the time, since I am looking for correct exposure and focus only for the subject.
I am also using a K200d.
04-08-2009, 04:06 PM   #11
esman7's Avatar
QuoteOriginally posted by octavmandru Quote
So by saying this, you're always have your subject centered in the frame? Sorry, bit confused.
Btw, thanks to everyone for your feedback.
04-08-2009, 09:10 PM   #12
QuoteOriginally posted by esman7 Quote
I use M mode (with old lenses, and new ones), spot meter once with green button, and keep the same settings till the lighting conditions change.
I don't worry too much, just check in the viewfinder the EV, for each shot, and decide if is necessary to make small corrections.
Center weighted works nice for me in P, and I guess in the other automatic modes too.
In the end, it's you who decide which mode fits better for a certain situation.
04-09-2009, 12:12 PM   #13
Marc Sabatella's Avatar
Not at all. In M mode, you'd center the target, hit the Green button to meter and set an exposure, then reframe. in any other mode, you'd hit AE-L instead of the Green button to lock the exposure before reframing.
04-13-2009, 02:51 PM   #14
AndrewG NY's Avatar
Color me suspicious on this as well. I have also assumed that treats that point like center for weighting purposes but still is using matrix metering. I don't usually use this setting but have imagined that it *might* be a decent idea when using P-TTL as you can't really do exposure lock & re-compose with a flash. Haven't verified how well this does or doesn't work.
I don't think deriving an experiment for this would be too hard.
camera, center, focus, love, pentax help, photography, spot
Multi spot metering mymage Pentax DSLR Discussion 15 06-04-2010 09:50 PM
Help with spot metering esorbo5 Troubleshooting and Beginner Help 12 07-22-2009 10:45 PM
Spot metering with split screens? gawan Pentax Camera and Field Accessories 11 04-15-2009 10:19 PM
Spot metering jdg Photographic Technique 11 05-25-2008 08:41 AM
spot metering wade7060 Pentax DSLR Discussion 7 04-22-2007 07:25 AM
All times are GMT -7. The time now is 08:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
