04-14-2009, 04:17 AM   #16
QuoteOriginally posted by greentea3 Quote
Oh well, it's a lesson learned. I'll see if a lens hood helps. It's a shame because the lens is beautiful and in exc. condition.
A hood will definitely help. Fortunately hoods are relatively cheap. You might even want to get both a "wide angle" hood and a "normal" hood to see which works best. I actually use a "normal" hood (the rubber screw in kind like this one):
RLH67 Adorama 67mm Rubber Lens Hood
on my Pentax FA 20mm F2.8 and it doesn't vignette, and helps muchly with flare control. Just be sure to get the correct diameter thread.
NaCl(hoods also help protect the lens from accidental bumps and fingerprints and the like)H2O
04-14-2009, 06:27 AM   #17
graphicgr8s
Guest
And to think Photoshop has a filter to create this effect and you want to get rid of it.
04-14-2009, 06:38 AM   #18
timbo13's Avatar
you can still get lots of good use out of it, just be aware of light striking the front of the lens.
04-14-2009, 01:25 PM   #19
Damn Brit
Guest
QuoteOriginally posted by timbo13 Quote
The ideal position for taking photographs is to have the sun at your back, other positions, as Tim says, you need to take care where the light source is coming from.
camera, examples, flare, hood, lens, pentax help, photo, photography
Lens Flare??? Maybe??? porterHause Pentax SLR Lens Discussion 3 05-16-2010 01:47 PM
Lens flare? War Machine 2112 Troubleshooting and Beginner Help 3 12-30-2009 08:16 PM
Very strange lens flare Eastern Shore Charlie Post Your Photos! 10 10-18-2008 09:58 AM
Sometimes Lens Flare Works konraDarnok Post Your Photos! 2 11-18-2007 03:01 PM
Strange lens flare NaClH2O Post Your Photos! 14 01-31-2007 12:17 AM
All times are GMT -7. The time now is 10:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
