Originally posted by essH This is not one of those "I've got a Ricoh and the pins are strange" pleas.
I've got an old Pentax Super A film body and it's clinging onto an FA lens I put on it this evening, with a view to running a film through on something more recent than an A or M series lens. The only thing is this - the lens won't release!
Has anyone had experience with this and found a way of solving it, please?
Is this the right part of the forum for this type of question?
Simon
(UK)
I assume this is you:
Every so often something goes wrong and it's at moments like these that a helpful tip comes in handy. I know this group has a wealth of talent and experience, so I turn to you for help.
This one is unusual for me - I have a couple of old Pentax film bodies that sit at the back of the shelf and get left behind when I pick up a digital body and use it. Tonight I decided to match a Super A with an FA lens - with a view to running a film through. But then came the shock - I can't get the lens off again!
I've tried the basics but nothing budges; the body is a good 'un but it's seen better days; the lens is much more valuable - an FA77 no less - even though I got it secondhand, it's still worth a fair bit, so I want to release it unharmed. But how?
When the lens is on the A setting, the release button allows no movement at all. When I turn the aperture ring to 1.8, the release button allows about an inch of so of turn before it stops.
Any ideas, please? The least destructive, the better.
I live near SRS and work in London, if that's in any way relevant to what you might suggest.
There isn't much that can get stuck on a DA and your super A body. The "A" contact is thrust out in the "A" position BUT it is also spring loaded so there is very little resistance here. The screw drive shaft should be flush to the lens mount so that shouldnt be a problem either. Only other real pin is the lens lock but since you can twist it 1" that also can't be in the way.
Unless the mirror is stuck in the up position, I don't see how it could be stuck.. sorry just drawing a blank
