Originally posted by Automan21k I just set my camera over to RAW and will start looking at PP software tonight. the light was all natural, but our house has several odd angled walls that defuse light in interesting ways, and 2 skylights over head for direct light, and the french doors with an awning over it to give indirect natural light.
The TV is facing away from the direction the picture was taken, but it is a 62" so it may still have been bright enough to affect the shot.
As a rule; when indoors with the lights on, I set the WB to the lightbulb icon. If there are flouresent lights, I adjust the "flourscnt" mode. There are three settings. Daylight colors, Daylight white, White light.
Outdoors is self explanitory; Sun icon, house icon for shade, cloud icon.
The lightning bolt if I use flash. Strobes are usually daylight balanced; the sun icon could also work for this as well.
I also use the manual adjust if I don't like what I see. This yields pretty good results under tricky lighting.
You could try the AWB, but I don't use it because I like having total control over my camera settings.
You can shoot in Raw and play with settings in PP except for manual which requires you to use the camera to get a reading off of a white wall or equivalant.
WB aint hard to master. You just gotta play with it. Sometimes it will not be perfect under tricky lighting. Just use whatever you can think of( changing camera angles, recomposing, etc.).
A tricky situation, for example, is shooting indoors in the daytime with windows open and lights on. That is when you may have to recompose and set the WB for a particular light source.
