04-19-2009, 11:17 AM   #1
mediaslinky's Avatar
Manual lens and Aperture Priority
Quick question. Want to know if my assumption is correct...
If you place my K100 on Av, and use a manual lens, the camera acts as though my aperture is wide open. It selects shutter speed, but only captures images with lens wide open.
Correct?
04-19-2009, 11:40 AM   #2
Stratman's Avatar
Correct. If you want to use manual lenses in AV mode, the M42 types are more suited for that. There is no coupler on those lenses, so they WILL be stopped down to your desired aperture.
04-19-2009, 01:43 PM   #3
jimH's Avatar
QuoteOriginally posted by mediaslinky Quote
Correct?
I've found that the only option that works for me with a manual lens on my k-10D, is to use the Manual - "M" mode on the camera. I Set the aperture to the setting that I want on the lens aperture ring, and then use the "green" button to momentarily close the aperture, take a light reading, set the shutter speed. If the picture is over or under exposed I tweak the aperture or shutter speed a stop and take another. Essentially you use a "Manual" lens on the K-10 the same way you would use it on any manual camera.
Now I'm unfamiliar with the K-100 and it's controls. I just checked the "Digital Photography Review" but I didn't see an equivalent to the K-10D's "Green" button on the K-100, maybe there is. But I've found that with any mode but the "M" manual mode on my K-10D will capture the images with the lens wide open, same as the experience that you are having with your K-100.
Wish I could be of more help, I'm sure that there is a K-100 user out there that can answer that question.
Jim
04-19-2009, 01:51 PM   #4
chalion's Avatar
K100D has a Av +/- button next to the shutter button which is equivalent to the green button on the K10D.
04-19-2009, 03:03 PM   #5
cardinal43's Avatar
QuoteOriginally posted by chalion Quote
I thought the AE/L was the equivalent to the green button. Of course, I could be wrong.
04-19-2009, 03:32 PM   #6
chalion's Avatar
You're probably right. I'd have to re-read the manual to be sure.
"AE-L button on M exposure Selects the exposure adjustment method when the AE-L button is pressed in M (manual) mode. (page 146)."
04-20-2009, 05:43 PM   #7
Thanks.
I figured as much when I tried it.
The AEL button works well, though.
aperture, camera, lens, pentax help, photography
manual focus, auto aperture 55? Impartial Pentax SLR Lens Discussion 4 10-12-2010 05:36 PM
Fixed aperture manual lens help Joe Troubleshooting and Beginner Help 7 09-01-2010 10:38 PM
Aperture Priority Shooting DSNAPP Troubleshooting and Beginner Help 10 01-09-2010 06:21 PM
setting menu for manual aperture??? rdrum76 Pentax DSLR Discussion 11 10-30-2007 02:35 PM
Aperture Limitations In Manual Mode? jshurak Pentax DSLR Discussion 6 07-26-2007 01:25 PM
All times are GMT -7. The time now is 03:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
