Originally posted by The WideBody i don't know what good is when using manual focus. when using my dad's spotmatic, it seems quite easy to focus manually. i can't imagine that it is much harder or easier when going digital
The viewfinder on the DSLR will probably be rather smaller than what you are used to. Might well be dimmer too, depending on the specific viewfinder you are accustomed to. Some film SLR's had a "split prism" screen where you focus not just by trying to judge if the images looks in focus, but via a scheme in which objects look they they've been sawed in half and not quite joined together right - the image is in focus when the two halves *do* join together right. That's the kind of focus screen people are recommending to aid with manual focus on a DSLR, because the viewfinder is smaller and perhaps dimmer than film cameras.
Personally, I find that with practice, it just isn't a problem. Even with the K200D viewfinder - which is smaller and dimmer still comapred to the K20D - I can focus well enough, although I do now use the O-ME53 viewfinder magnifier to make the image closer to the K20D in size. It's still a lot smaller than most film cameras, though.
No hurry on upgrading the focus screen or viewfinder though - get the camera, see if you can deal with it OK, and if not, you can get the new screen or the magnifier later. The magnifier is cheap under $50. The focus screens are available in cheap (also under $50) or more expensive (over $100) versions, and there is endless debate on whether the more expensive ones (like the Katz Eye) are worth it.
