04-23-2009, 09:32 AM   #1
esman7's Avatar
Big time noob Q #2
I thought I'd give you all a break to answer some real easy stuff.
I've used the EV function quite a bit to brighten or darken shots that need some fixing, but what is it actually doing? For example, if I increase to +1.0 EV, is the exposure increasing via increased shutter speed or faster aperture (or something I don't even know about?)
Thanks!
oh and btw, how come in my User CP, threads i've posted don't show up in the subscribed threads tab? Thanks again!
04-23-2009, 10:06 AM   #2
foxglove's Avatar
QuoteOriginally posted by esman7 Quote
Depends on the mode you're in - in Av or Tv mode, it changes shutter speed or aperture, respectively. In other modes, I have no idea, I took a quick look and it seemed rather random - but you can look at the settings and watch them change as you change EV, and maybe figure it out.
I think you have to set something in your profile so that you're automatically subscribed to threads you post in. Dig around, I recall it was pretty self-explanatory... once I found it!
Julie
04-23-2009, 11:11 AM   #3
Marc Sabatella's Avatar
EV compensation can only change ISO, shutter speed, or aperture - those are the only things that can affect exposure. If you're in a mode where *you* select one or two of those parameters (eg, in Av you select aperture; in TAv you select both shutter speed and aperture), then it will change one of the *other* parameters, according to whatever voodoo it chooses.
04-23-2009, 11:12 AM   #4
heliphoto's Avatar
QuoteOriginally posted by foxglove Quote
Julie
On the K20D (what I have next to me for reference), this is only 100% true when your ISO is set to a fixed setting - if I have ISO set to Auto, EV compensation will sometimes vary ISO, leaving shutter speed alone rather than slowing it down "too much". You can set a fixed ISO, and the camera will have to do EV comp. with the shutter speed (in Av mode).
EDIT: Just gotta say that Marc's answers are invariably more succinct and educational than mine - it's embarrassing .
04-23-2009, 12:25 PM   #5
foxglove's Avatar
EV compensation can only change ISO, shutter speed, or aperture - those are the only things that can affect exposure. If you're in a mode where *you* select one or two of those parameters (eg, in Av you select aperture; in TAv you select both shutter speed and aperture), then it will change one of the *other* parameters, according to whatdever voodoo it chooses.
Heh, camera voodoo, I like!
QuoteOriginally posted by heliphoto Quote
Yeah, well at least you didn't entirely forget about ISO... serves me right for dashing off an answer without thinking about it. I usually nail the ISO down at 200 (lowest on K100) because I shoot primarily during the day, outdoors, in full light, and I don't like things changing without my knowing, with the result that I sometimes forget that ISO can be adjusted!
That's what great about this forum, it keeps you on your toes...
Julie
04-23-2009, 03:58 PM   #6
Thanks for those comments! It helps that I've probably answered variations on this same question 100 times before :-). You get good at explaining something when you do it over and over.
04-23-2009, 10:52 PM   #7
res3567's Avatar
Hey Marc?
Were is the voodoodoo setting on my K10D?
On my mode dial I see all the AE modes and an X.
Does X mark the spot?
04-23-2009, 11:01 PM   #8
Ash
Community Manager
Ash's Avatar
Well,
there's the aperture voodoo (Av mode), the time voodoo (Tv mode) and the total abominal voodoo (TAv mode)!
04-23-2009, 11:14 PM   #9
res3567's Avatar
Well,
LOL Bigtime!
04-24-2009, 11:21 AM   #10
Changing the Ev value effectively changes the result of the light measuring subsystem as it is passed on to the exposure subsystem. So, the camera will act as if the light was more or less than captured as dictated by the Ev compensation set.
You might get the same (or better) results using another approach.
I don't know what camera you have, but my K10D can link the light measuring to the focus point used, by changing one of the user settings.
Also you can do spot metering. By using these two possibilities that you can often avoid manually changing the Ev.
Yet another option working to my satisfaction is by using the Auto Exposure Lock. Point (either in spot or not) to a scene which is lit like you want to. Half press the shutter while holding AE-L. This will freeze the exposure value for 30s. Now recompose your shot and press the shutter.
I hope this helps.
- Bert
04-26-2009, 09:04 AM   #11
esman7's Avatar
Thanks all.
camera, ev, pentax help, photography, thanks, threads
It's Time for the Big Event............ Parallax General Talk 11 11-07-2010 10:05 AM
Blown Opportunity BIG TIME--please help! oatman911 Photographic Technique 26 01-07-2010 04:03 PM
Big time Noob Q esman7 Troubleshooting and Beginner Help 14 04-24-2009 09:32 AM
My k10d is failing big time CreV Pentax DSLR Discussion 2 11-23-2008 05:28 AM
Big Problem with my Video Card..I think...Big Ca Ca benjikan General Talk 19 03-18-2007 11:45 PM
All times are GMT -7. The time now is 12:02 AM. | See also: NikonForums.com, part of our network of photo forums!
