04-27-2009, 10:16 AM   #1
Purchase path?.. what's next?
Hi everyone,
Just starting in world of photography.. I picked up a K200D.
But I am not too happy with the lens. A big part of it is probably my own problem with camera settings, etc. But I think this lens can't really meet all of my needs right now.
I don't intend to carry around a lot of different lens / equipment, as most of the stuff I want to shoot is just whatever I see when I'm on weekend trips around the city / country. So pretty much looking for an everyday lens that can have a reasonable zoom, and can get pictures well both indoors and outdoors.
This lens I'm using right now.. I can't really get a nice depth of field effect at all, I found..
Anyways, suggestions at all would be great. Want to get absolutely under 500, but cheaper is good.. I don't have an unlimited budget at all.
Was considering this, "Tamron AF 28-75mm f/2.8 SP XR ZL Di LD Aspherical (IF) Lens" and "Tamron 17-50mm F2.8".
04-27-2009, 10:49 AM   #2
Check out the Sigma 18-50mm f/2.8.
Or just get a 50mm f/1.4.
04-27-2009, 10:53 AM   #3
Marc Sabatella's Avatar
Use the lens you have to get a feel for whether you'd miss that 18-28 range more than you'd appreciate the 50-75 range or whether it would be the other way around. You do indeed want an f/2.8 zoom to get the shallow DOF effects you refer to, but be aware that's still not going to be *all* that shallow. If you *really* want shallow DOF, you need a prime - so getting something like the 50mm mentioned above *in addition* to the zoom you already have might make more sense.
04-27-2009, 11:47 AM   #4
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by Temoin la Nuit Quote
........................Was considering this, "Tamron AF 28-75mm f/2.8 SP XR ZL Di LD Aspherical (IF) Lens" ...............
Nice lens IF you are lucky enough to get one that focuses. I would consider the Pentax 17-70. I have one and love it. Remember that one of the benefits of using a Pentax camera is the ability to use Pentax lenses.
04-29-2009, 07:43 PM   #5
panoguy's Avatar
QuoteOriginally posted by Parallax Quote
Yes, but Pentax new lens pricing is insane in Canada. The Pentax 17-70 is $830, and max aperture of f/4 may not be shallow enough DOF for the OP.
I'd highly recommend the Pentax 50mm f/1.4 as it is still a bargain (even at $300 CDN) and has more DOF then you will likely ever need. The fact that it isn't a zoom can be an advantage as well - it limits the perpsective, so you start to consider things like DOF and composition. But then it sucks for general walk around, so keep the kit lens.
04-29-2009, 08:12 PM   #6
Robert S Donovan's Avatar
I could recommend a number of lenses but I'm afraid that you might still be unhappy. Can you elaborate a bit more about the "depth of field effect" you are after?
04-30-2009, 04:14 AM   #7
As mentioned above, the DA 17-70 is $499 on Amazon right now and would cover the whole range with a constant aperture of 4. If the goal is shallow depth of field, I would favor getting a prime in the range and using that in conjunction, say the DA 35, FA 50 or FA 35 would all work well.
camera, lens, pentax help, photography
Landscape Rocky Path ajuett Post Your Photos! 5 02-07-2010 08:48 PM
Nature Fall path ohfrankyboy Post Your Photos! 2 10-12-2009 08:39 PM
Winter Path ajuett Post Your Photos! 6 03-18-2009 10:05 AM
Path Of Bokeh Nitrok Post Your Photos! 18 11-08-2008 03:12 AM
two-path lukastrika Post Your Photos! 2 02-23-2007 02:39 AM
All times are GMT -7. The time now is 08:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
