04-30-2009, 07:45 AM   #16
reeftool's Avatar
A good sharp prime lens will produce a very good cropped photo if you have to crop. I try to use the right length lens for the shot when i'm using a prime. If I have to crop every shot a lot then I'm using the wrong lens. The stuff that I do crop a lot is with the longer telephotos because I can't afford the lens I would like right now. In poor light where I have to shoot wide open, a cropped shot with my Takumar 200mm f4 will be much better than my Sigma 70-300 because its a much better lens. I don't think i'm wasting pixels. I do use the zooms a lot more because it's convienent.
04-30-2009, 08:00 AM   #17
AndrewG NY's Avatar
Nicely put. I suppose if you only own one prime and try to use it for shots for which is not well suited, then you'd have to crop. But the completely misses the point of using primes.
After reading your response, I realized I accidentally transposed "need" & "mean"...but I think you got my point anyway. The main time I know people start doing this is when they are shooting wildlife with their longest lens and it still isn't long enough. That's life...some of us just aren't willing to buy and/or carry SLR lenses > 300mm or so. And there may be some validity to this approach--you just might get better results cropping from a high-quality 300mm prime vs. a softer & slower 400mm zoom. But using a shorter prime like a 50 instead of a longer telephoto is essentially like "digital zoom" that most of us know is a serious quality compromise.
04-30-2009, 08:33 AM   #18
A person looking at a certain size displayed image can resolve only a certain number of pixels. Doesn't it follow that a sensor's pixels in excess of that number are "wasted"?
Now maybe there's a lower limit to the number of sensor pixels required to make an effective display pixel, but that doesn't change the thrust of the argument.
Iowa Dave
04-30-2009, 02:23 PM   #19
Sensor resolution + lens resolution = final cropping ability.
The greater each resolution is, the more you can crop without penalty. The combo of my DA* 300 and my K20D gives me enough crop ability that I can smoke many much bigger guns out there.
Jack
04-30-2009, 11:09 PM   #20
Jewelltrail's Avatar
ntx: Is there a flaw in my thinking? How often is cropping needed when using primes?
Proper composition eliminates the need to crop. More experienced shooters compose better and therefore need to crop less. Your thoughts apply to an inexperienced shooter, not yet skilled enough to maximize a prime's utility, but who might be able to compose better making use of the zoom's versatility.
ntx: Also I read reviews that talks about cameras (that have 15/20 megapixels) which are good because of their cropping possibilities. Looks strange for me to pay for tenths of megapixel in order to crop them down...
It is true a 15 or 20 MP DSLR has more "cropping power" than a 5 or 10 MP camera. But remember, 15 or 20 MP is rarely needed by most people in order to print. Many people make high quality 11 X 14 prints with a 6 MP camera. So you are not wasting any mega pixels if you get the image you want and print it successfully at the size you want.
ntx: A question arises: does a prime lens just waste sensor's mega pixels?
When used correctly, a prime will make better use of a camera's available mega pixels, because primes (most of the time) outperform their zoom counterparts in IQ. However, there are excellent zooms which outperform some lesser primes.
05-01-2009, 09:24 AM   #21
QuoteOriginally posted by Jewelltrail Quote
It's been a while since I've read a more condescending post. There are many situations where cropping is needed. Not every photographer has his or her environment under such control that they are able to guarantee the "right" composition. Condescension reveals the narrow mind.
05-01-2009, 09:55 AM   #22
jbinpg: It's been a while since I've read a more condescending post. There are many situations where cropping is needed. Not every photographer has his or her environment under such control that they are able to guarantee the "right" composition. Condescension reveals the narrow mind.
Sorry if my words appear condescending to you---my intention is only to help. May I ask you the following questions?
Did I ever say cropping is never needed?
Who composes better, experienced or inexperienced shooters?
Did I ever say any photographer has his/her environment under complete control?
Did I say I consider myself an experienced shooter? (one of the reasons I bought the K20 was, indeed, for its cropping power)
My point is a prime, usually, has more potential to maximize a camera's mega pixels, but that an experienced shooter is more apt to tap into that potential.
05-01-2009, 10:27 AM   #23
reeftool's Avatar
I agree with the practice of proper composition but most of my cropping is because I don't have a lens long enough and can't afford to buy one right now. A lot of us enjoy getting outside and shooting pics of birds and wildlife and don't have those long, fast lenses the pros use so we get the best glass we can afford and crop if we need to.
05-01-2009, 10:44 AM   #24
I have to respectfully disagree that primes are sharper than zooms. Unless you are a pixel peeper, a high quality zoom is indistinguishable from a prime. There are definite benefits to primes -- they are often a little cheaper, are much smaller and are faster, but at the same apertures, they are not sharper.
This is of course assuming a quality zoom - DA 16-45, DA* 50-135, etc.
05-01-2009, 09:19 PM   #25
res3567's Avatar
Have you compared a prime vs. a high quality zoom?
Show us your evedence.
Post the pics.
05-01-2009, 09:34 PM   #26
Venturi's Avatar
With tongue in cheek I offer my "esteemed" opinion of the three situations where one needs to crop:
a) You can not get close enough to your subject with the focal length(s) you have (moving planes, trains, automobiles, etc.).
b) You should not get close enough to your subject with the focal length(s) you have (lions, tigers, bears & brides).
c) You screwed up and didn't get as close enough to your subject...
In my case it is nearly always c)
05-01-2009, 09:36 PM   #27
I'm surprised no one has told the OP to hold off buying that k200 and wait for the k-7 to drop...
05-01-2009, 10:50 PM   #28
Ash
Community Manager
Ash's Avatar
My .02 worth would be to say that there's more to lenses than resolving power.
ie. Primes, even if better resolving than zooms, generally have better colour rendition, contrast and are faster than zooms.
Nevertheless today's zooms (like the DAs) are VERY good and have almost everything that primes have in terms of IQ bar the speed. But again, bear in mind that zooms also have their weak spots that if compared with primes would pale in performance, eg. it's probably unfair to compare the DA 12-24 at 24mm to the FA* 24 or a DA*16-50 at 16mm to a DA* 15
05-01-2009, 10:54 PM   #29
res3567's Avatar
QuoteOriginally posted by Venturi Quote
b) You should not get close enough to your subject with the focal length(s) you have , bears & brides).
LOL!!!!!!!!!!
05-01-2009, 11:38 PM   #30
Marc Sabatella's Avatar
FWIW, taking this list seriously (and it *is* a good list), there is one important thing missing:
d) changing distance to subject would adversely affect the perspective
That's actually the strongest argument n favor of zooms, in my opinion. "Zooming with one's feet" changes perspective; changing focal lengths does not. Ideally, you'd first choose your position based on perspective concerns, then chosoe the focal length that provides the best composition from that perspective. If you don't have that focal length available, then that's where you'd want to shoot shorter and crop.
Still, if you have a decent assortment of primes available, you wouldn't have to crop *much* - and it's also possible that a small change in position wouldn't *entirely* ruin the perspective.
camera, crop, lens, lenses, megapixel, megapixels, pentax, pentax help, photography, primes, question, sensor, shot
Question about megapixels justtakingpics Troubleshooting and Beginner Help 7 05-13-2010 10:09 AM
Megapixels vs. Noise stgmgr Troubleshooting and Beginner Help 7 02-24-2009 12:37 AM
6.4 Megapixels at 60 fps falconeye General Talk 11 02-13-2008 08:18 AM
Megapixels and cropping pcarfan Pentax DSLR Discussion 11 09-30-2007 05:13 PM
K10D at 2 Megapixels erollin Pentax DSLR Discussion 7 08-29-2007 04:55 PM
All times are GMT -7. The time now is 05:49 PM. | See also: NikonForums.com, part of our network of photo forums!
