I've come to the conclusion that it's impossible to totally remove all the dust and oil off the filter.
I tried everything. I even washed the complete filter in the sync with dish washing liquid. Then rinsed with warm water and blow dried with the hair dryer.
So far this gave the best results. But I still found as it dried it left a streak where the water edge dried from.
Trying to use the micro fiber cloth just smeared everything around again and added fine dust.
I have washed the micro fiber cloth too a number of times and let dry.
Out in bright daylight the filter actually looks very clean. But when I use a LED lit Mag Light inside and reflect it off the IR coating you can see the residue.
I do wonder whether any of this really matters as far as picture quality etc too.
Can filters and lenses really be cleaned to perfection?
One other thing I noticed is that even after a reasonably good clean, in bright light with the reflective effect of the black IR filter you could actually see the fine particles of dust floating down on to the surface.
Anyhow, this becomes yet another interesting learning curve for me with DSLR. Keeping your gear clean.
