05-05-2009, 08:49 AM   #1
Silhouettes
Maybe this is a bit ambitious for a relatively new photographer..
I have been taking photographs now for about year.. but I've only been using a film camera for a course, and now I've moved onto digital and was wondering how I could create a sihouette..
My idea was.. to have a person staring into a mirror, so you could see the person in the mirror, but also the person as a silhouette outside of the mirror if that makes sense, so it portrays a transaction of nothingness to detail.. iif that makes sense.. just an arty shot idea.. It may sound a bit too ambitious.. since I am not very experienced.. and may be impossible, just thought this was the place to see if it was possible, and how to it.
Cheers,
Ryan
05-05-2009, 10:23 AM   #2
Try it
Sometimes the best way to learn is by experimentation. So try some shots. It doesn't cost anything with a digital camera.
I'm not sure what you want to do but it may be best to focus on the image in the mirror and have the face of the person in the frame while using a high f-stop (f11?).
Good luck.
05-05-2009, 10:41 AM   #3
kibipod's Avatar
Let's say the mirror is on a stand i.e. dresser. You place your subject in front of the mirror. In this situation both subject and mirror are foreground. Now you place a light source like a lamp or a flash between your subject and the wall. Make sure the lamp is not visible through the camera and also not by the mirror. If you can place the subject and the lamp in such a way and place your camera in such an angle that you see your subject and his/her image on the mirror, then you can make a silhouette. You need powerful light source to make the background (in this case it is the wall) really bright compared to your subject who is nearer to the camera and is on the foreground. The powerful reflected light will illuminate the subject.
This type of composition is possible on a stage and difficult inside a regular room. If you have access to a theater stage and some props, you can achieve what you are looking for. You need good separation of subject + mirror from the background wall. Otherwise light will spill over to the subject 's back which is facing the camera and will not render that silhouette effect. Placing the lightsource near the subject will ruin it as there will be wrap around light.
05-05-2009, 12:14 PM   #4
I'll give this a shot..
Might post end result if it is of a acceptable nature :P.
Thanks very much for both of the replies,
Ryan
05-05-2009, 12:23 PM   #5
Damn Brit
Guest
I suspect there would be too much ambient light to get a decent silhouette AND reflection. You could try two shots and merge them.
05-05-2009, 03:40 PM   #6
Ira
Just a suggestion:
It's not really good to post in all bold, but to save bold for those words you want to emphasize.
05-05-2009, 04:30 PM   #7
Damn Brit
Guest
Just a suggestion:
Thanks for that, you're right, people do tend to get fed up with it.
05-06-2009, 06:42 AM   #8
res3567's Avatar
QuoteOriginally posted by Damn Brit Quote
Hi! How are you?
05-06-2009, 06:42 AM   #9
res3567's Avatar
Hi! How are you?
05-06-2009, 06:43 AM   #10
res3567's Avatar
Hi Gary! How are you?
05-07-2009, 08:33 AM   #11
Thanks for the tip?
I'll bear that in mind!
05-08-2009, 06:08 PM   #12
Damn Brit
Guest
QuoteOriginally posted by res3567 Quote
I'm fine thank you. Can we get back to normal typeface now please?
05-08-2009, 07:15 PM   #13
res3567's Avatar
Yessir! Ha!
05-09-2009, 09:34 AM   #14
Another possibility for a silhouette is to place the subject with in a strong backlight (like a bright sunny day and a white wall). Expose for the backlight and voila! the subject will be silhouetted. It happens to me all the time when all I want it some backlight
NaCl("curses! over metered again!!!" )H2O
bit, camera, mirror, pentax help, person, photography
Black & White Silhouettes tuco Post Your Photos! 7 05-18-2010 08:58 PM
Winners: Project 52-2-23: Silhouettes Ash Weekly Photo Challenges 7 12-28-2009 08:55 AM
PROJECT 52-2-23 Lighting: Silhouettes mithrandir Weekly Photo Challenges 24 12-23-2009 01:12 PM
Silhouettes of the night Rense Post Your Photos! 14 03-30-2009 02:29 AM
Figure silhouettes creampuff Post Your Photos! 7 02-24-2009 02:41 PM
All times are GMT -7. The time now is 11:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
