(Sorry if there's a double post)
I've been trying to use my old k-mount manual lenses with my K10D and it hasn't been going well. Hopefully you guys can help me out.
I've followed all the steps. 'Using aperture ring' is set to permitted, 'Green button in TAv & M' is set to Tv shift (I've tried the default of program here as well), and the Preview Method is Optical Preview. I'm shooting in manual mode. although I've tried every other mode as well. I've also made sure to put it into manual focus.
Here's what's happening: I can take pictures, and the camera adjusts the shutter speed according to the available light, but -only- at the maximum aperture, so 2.8 when using my 28mm prime.
I get the F - - in the viewfinder and LCD display, that's normal. But when I move the aperture ring and hit the green button, it has no affect on the shutter speed. I can take a picture at an aperture of 2.8 or 22 and it comes out exactly the same, with exactly the same shutter speed!! I've looked through the lens and twisted the power switch to the aperture preview symbol, and I hear it move, but it is just closing down to the widest aperture, never down any lower than that. This applies to every old k-mount, manual focus lens I use.
My 28mm lens even has an auto-aperture position on the aperture ring. Using that position, F-- goes away and I can see an aperture designation in the viewfinder and LCD screen. However, it still only shoots at the max aperture, no matter what I do. I can set it to 2.8 with 1/30 shutter speed and 22 with 1/30 shutter speed and both pictures come out exactly the same.
Just now I decided to look at my kit lens and see if I can see the aperture drop down when I set it to ap 22 in manual and hit optical review or the green button. I cannot. I then took some test shots, one at shutter speed 1/30 and ap 5.6, another at 1/30 and ap 22. They both exposed exactly the same.
What's wrong with my camera? Is it a hardware problem or a software problem?
History: I've had the camera for about a week. I can't say for certain if this part of the camera ever worked properly, but I am pretty sure I remember looking through the viewfinder, setting it to low ap, hitting the optical preview, and seeing the viewfinder darken and my depth of field increase. I also did this with my film camera this week, so I can't be certain if it ever worked at all on my K10D! I know, I'm terrible!
Further history: I got a lens stuck on the camera. A JCPenney 28mm AP lens with a back lens cover that says KR on it. I didn't notice that until after I had the lens on. It came with my K1000 and worked with it, so I assumed it would be safe to use on the K10D. After about 5-10 minutes of wiggling the lens, and using a very, very thin flathead to (very) gently try to lift the pin that was stuck (read some threads online about stuck lenses on K10D), it came off. However, it came loose when I was just wiggling it gently, not when I was using the flathead screwdriver. I was not applying a large amount of force, but certainly more than I felt comfortable using with a camera. I then removed the pin from the lens and it would go on and off of the K10D without issue.
The camera came with firmware 1.0. I updated to firmware 3.0 the other day, and noticed this aperture issue after that. The lens got stuck on the camera before I updated the firmware.
So the problem could be either from the firmware update, from the lens getting stuck, or it could have been there from the day I bought it. Here's a picture of how far the rod comes out when you hit the green button or optical preview without a lens attached. I'm sorry for the poor quality, but all I had available at the time was a point and shoot that didn't want to focus on anything but the grip.
Please help me fix this. I dearly hope it is not a physical problem with the camera! I can't imagine having to send it in for repair or replacement so soon.
