05-07-2009, 03:55 AM   #1
jaitas's Avatar
K10D "Sensor moving" possible problem?
Hi
Just noticed that when I tilt my K10D sideways theres quite loud "thump" sound coming. I mailed local pentax repairer and they said it's normal sensor movement.
That's what I thought that it's sensor movement, but what I wonder is that is it possible that I havent noticed this thing for the whole year I've had this body!? And because the sound is quite loud too.
Also camera hasn't been mishandled, and shuttercount is around 17 000 so that should not be a problem.
I also tested this by arrangin my tripod and quick release plate, took one picture after tilted camera to left, then another when tilted right. And the perspective changed slightly. (of course there's possibility of human error, but I tried to be very careful
So what do you think, is this something to worry about or not, camera works just fine.
Thank you in advance!
Greetings
-Juho
05-07-2009, 06:14 AM   #2
That is normal sensor movement while the camera is off. The sensor-shift SR allows of the sensor to compensate for camera shake. Are you saying that this happens while the camera is on? Is SR on when you hear this sound?
05-07-2009, 08:58 AM   #3
OregonJim's Avatar
QuoteOriginally posted by jaitas Quote
Perspective only changes with front-back movement, not side-side. Do you mean the framing changed slightly? Were you using a zoom lens? Perhaps the tilting of the camera from side to side moved the zoom ring ever so slightly...
05-07-2009, 10:27 AM   #4
jaitas's Avatar
Thanks for the answers.
And yes, the sound is there even if camera is on, and i'm pretty sure it is'nt shake reduction because I can clearly hear something "falling" when I tilt the camera.
And yes, I'm saying that framing changed side-to-side and the lens I was using is DA 35mm ltd. Also there's plenty of room for human error even though I tried to be careful! (I took pictures of bottles and they moved slightly sideways after I tilted the camera and re-took the photo)
greetings
-juho
05-07-2009, 12:37 PM   #5
My K10D does the same, has done the same for as long as I have it.
There has been a number of discussions on this sound in the past on this forum.
Speculations as it was the orientation sensor or the image sensor moving around have not been confirmed.
The sound is a somewhat dimmed "clonck" that sounds almost the same as the a single dust removal click.
My best guess is that it is the battery, it has some space at the bottom end in the battery compartment. Moving the battety around with my finger with the lid open, produces a similar sound.
Most probably your camera is in fine condition still.
- Bert
05-07-2009, 12:52 PM   #6
jaitas's Avatar
That sounds reasonable and probably that's what it is. I was just left wondering that I noticed this sound just now. After owning and using camera for a year
anyway, thanks to you all for the answers!
-Juho
05-07-2009, 02:08 PM   #7
Marc Sabatella's Avatar
You're not alone; lots of people manage to not notice it at first - sometimes, not until it is pointed out to them!
camera, k10d, movement, pentax help, photography, sensor, sound
Sensor shift during "long" exposures eclipsed450 Pentax DSLR Discussion 11 12-18-2009 12:51 PM
K10D owner moving to K-7: Early "Review"/thoughts on the K-7. (link to Images) pcarfan Pentax DSLR Discussion 6 08-02-2009 07:59 PM
Pentax "A" lens and "F" 1.7X converter on K10d yyyzzz Pentax SLR Lens Discussion 4 07-09-2009 05:04 AM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
"Green Clean" Sensor Cleaning System. NLAlston Pentax Camera and Field Accessories 2 05-16-2007 07:35 PM
All times are GMT -7. The time now is 08:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
