05-10-2009, 12:41 PM   #16
Canada_Rockies's Avatar
QuoteOriginally posted by Tom S. Quote
There is no logical reason to believe a large card uses significantly more battery power than a smaller one. However, since a larger card will hold more pictures than a smaller one, you would be writing more to it - which does use power, especially if you are shooting raw.
There is lot more than memory card size that effects battery life. For instance, how long camera stays on before automatically shutting down, how much your lens focuses, how much you use the flash (big one there!), how long the display is set to show results, etc.
Right on, Tom. I do not enable the automatic review. When I need to review I push the playback button.
camera, class, pentax help, photography, sdhc
K-x Non Use Battery Drain gkbain Pentax DSLR Discussion 20 10-31-2010 09:08 AM
K100 battery drain hiddenhallow Pentax DSLR Discussion 9 08-31-2010 03:14 PM
Misc The Drain spyglass Post Your Photos! 6 11-30-2009 06:06 PM
Fast Battery Drain in BG2 Grip rickn Pentax Camera and Field Accessories 4 10-29-2009 05:15 PM
Suggestion Knowledge Base Jodokast96 Site Suggestions and Help 2 07-19-2008 05:26 PM
All times are GMT -7. The time now is 08:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
