Originally posted by Dom Don't forget the K20D has 'catch in focus' which can be quite usefull
All Pentax AF SLR cameras will do CIF with a manual focus lens and the camera in AF.S.
Originally posted by marius Do I need to use manual A lenses only? or does 'catch in focus' works with any MF lens?
If it is a lens, it will work.
Originally posted by GeneV I've found that to be the case as well. Relying on the confirmation leads to an overshot almost every time.
It's too bad I scratched my Chinese split screen putting it in. At least it wasn't a Katzeye.
As one who has used MF lenses continuously from 1961, I can say that the technique that works is to rock back and forth between too far and too close. After some decent practice time, you should be able to do it in no more than four movements, even if you lens is wide open. Stopped down, you can do it in less. Overshoot, Overcorrect in the opposite direction, nail it. This works best with lenses with long throw focus rings, as your over/under is not very far from the actual focus point.
