05-14-2009, 05:30 AM   #16
Mike.P«'s Avatar
A classic example of purple fringing.
05-14-2009, 06:32 AM   #17
meszidik's Avatar
Along the same lines: I understand the concept of CA, but I am not sure what it looks like. Any good examples of CA ?
05-14-2009, 09:00 AM   #18
QuoteOriginally posted by meszidik Quote
Here is some fairly mild CA on a 100% crop from my Vivitar 135/2.8. Note the color fringe on the top edge of the board and (to a lesser extent) a matching fringe on the bottom edge.
05-14-2009, 05:22 PM   #19
meszidik's Avatar
Thanks that helps.
-Mark
05-15-2009, 04:31 PM   #20
QuoteOriginally posted by OregonJim Quote
FWIW, I've never seen PF on film. From what I understand, it is a Bayer-pattern specific phenomenon that is aggravated by certain lenses that are not apochromatic - that is, not all of the color spectrum is focused on the same plane.
I always thought that it was largely sensor related, especially since my K10 shows PF significantly more than my DS, K100S, or K20 -- with the same lenses, shooting similar scenes with very high contrast. I do a lot of this since I'm primarily a bird shooter.
. . .Then I went to my opthomologist to get my eyes checked for possible damage from diabetes. They gave me the drops to dilate my pupils, and until this effect wore off, I noticed significant PF around the flourescent panels in the office, and around the trees against the sky when I went outside. I've had my pupils dilated before, years ago, but had never noticed it -- recently acquired digital photographer's perspective I guess. . .
I asked the Dr at my next appointment, and he said he'd never heard of it, and couldn't explain it. I just don't know enough about it to guess.
My answer to PF in PP is to use the color option in the clone brush in PSP with the opacity at about 25-40%. It's a bit time consuming, but can give great results for important images as it's not just a desaturation which just turns the purple to gray. This also can be used effectively on green/red CA. Just clone the color from an appropriate area from anywhere on the frame.
Scott
camera, film, matter, pentax help, photography
Sports "Highside Exit" took 1st Place in DPReview "Missed It by THAT much, Part 1" Challenge MRRiley Post Your Photos! 27 02-21-2010 08:26 PM
K20d-Frame Count on panals..works w/"M" & "P" mode only? arbib Pentax DSLR Discussion 1 08-28-2009 05:47 PM
"Purple Haze" mrreece Monthly Photo Contests 0 11-28-2008 09:06 PM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
Anyone bring "E2" fluid or the "Digital Survival Kit" on a plane? m8o Photographic Technique 2 07-31-2007 06:20 PM
All times are GMT -7. The time now is 09:28 PM. | See also: NikonForums.com, part of our network of photo forums!
