05-13-2009, 10:27 PM   #1
pentax k200 with f8 600mm telephoto lens
hi, i recently bought a k200 and have been able to fit an old 600mm mirror telephoto lens onto the camera, but i do not know how to tell the camera its a fixed f8 lens???? i am able to get dullish shots when i turn the iso to 400 but anything less than that just comes out black, i would also like to be able to use a faster shutter speed for sports and have bright/clear photos, is this possible
when im using it the shutter speed is shown but f just has this f-- flashing.
05-14-2009, 01:17 AM   #3
1. set camera to manual focus
2. set camera to AV mode
3 set in custom menu use of aperture ring permitted
Assuming the lens is installed correctly you should be good to go.
f/8 is pretty slow so don't expect too much for this lens as an action stopper.
Mirror lens' will tend to give you rather dull low contrast shots so pump up contrast and saturation in the camera settings.
05-14-2009, 01:17 AM   #4
QuoteOriginally posted by stone84 Quote
Well, a lens with a fixed aperture is just that.. A lens with at fixed aperture. The only way you can achieve faster shutter speed is to increase the ISO. You have to remember that F8 is a very slow/dark lens and you'll need a very high ISO to actually achieve a shutter that is fast enough to avoid motion blur on 600mm. Probably you'll end up with ISO 800 or 1600 in most conditions.
Also you can forget about shooting in Tv mode as the camera have no way to alter the aperture for you, in Av you'll just get a probably "not so well working" auto. The only real way to use such a completely manual lens is to get into M-mode and use the green button to meter for you.
05-14-2009, 02:40 AM   #5
Also if you have an external hand held light meter, you could use that to get your shutter speed, and then fine tune it with a few shots.
05-14-2009, 05:01 AM   #6
cheers
cheers guys, i got the hang of now.
Also can you mount a fisheye lens over the end of telephoto lenses? i.e. so i can take fisheye surf shots from land
05-14-2009, 07:38 AM   #7
OregonJim's Avatar
Ummm, you can *try* it, but don't expect it to look like anything except a shot from a really crappy 300mm lens.
600mm, camera, f8, k200, lens, pentax help, pentax k200, photography, shutter, telephoto
Can the kit lens of my k200 work on the pentax SF1? SamGarri Pentax SLR Lens Discussion 3 10-11-2010 07:15 AM
SMC Pentax Zoom 1:6.7 135-600mm - Legendary Super Lens! Clinton Pentax Price Watch 0 03-25-2010 10:51 PM
For Sale - Sold: Pentax SMC A645 A*600mm F5.6 (ED)(IF) Lens (Worldwide) oneill Sold Items 0 03-10-2010 09:20 PM
For Sale - Sold: [US] Vivitar 120-600mm Telephoto Zoom HogRider Sold Items 8 03-08-2010 04:41 AM
K100D 500mm-600mm Telephoto for Surf Photography jeffski Pentax SLR Lens Discussion 7 09-13-2008 10:16 PM
All times are GMT -7. The time now is 11:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
