Originally posted by Falld5 I'm using the SEL setting most of the time. Well, okay, all of the time.
I thought that having it set to SEL allowed me to pick where I wanted it to be focused...
It lets you specify the general area, not the exact spot. When you move the little red square around, you're saying, "focus somewhere near here", but it might still be a little above. below, or the side of the actual square, because the AF sensors are larger than the squares.
Quote: I have found that there is a little green light that blinks in a different portion of the screen
The green hexagon tells you *when* focus has been achieved; the red squares tell you *where* (again, just approximately).
Quote: What settings does everyone else use and how do I KNOW where it is focusing and make if focus exactly where I want it to?
I use center point only, and point it where I want to focus, then recompose. It works just fine 99% of the time, despite issues that can come up in rare situations.
But by "just fine", that doesn't mean one can always make the camera focus *exactly* where you want - again, you can just choose the general area.
