05-18-2009, 09:20 AM   #1
irishwhite's Avatar
Reverse Mount Adapter
Hello, I'm looking at picking up a reverse mount adapter for my old 50mm f1.4 and am confused about something.
will a 52 mm adapter work, or do I need it to be 49mm? I belive the filter size is 49 mm but when I do a quick search on ebay, all I see are 52mm adapters. Right away I'd just assume those won't work, but then I saw THIS thread and if you look at the image in the thread it looks like the adapter will fit both.
any help would be appreciated. Thanks!
05-18-2009, 09:48 AM   #2
its the filter size you need to match up since you are turning the lens around and screwing it in.
05-18-2009, 09:55 AM   #3
irishwhite's Avatar
QuoteOriginally posted by jmbradd Quote
Thanks for the reply and yes, i'm aware of needing to match up the filter size. I just didn't understand how the literature that comes with the reverse mount adapter that was recently sold (in the topic i linked to above) said 49 mm and 52 mm on it. Unless pentax made two different reverse mount adapter sizes and just used the same manual for both?
05-18-2009, 10:18 AM   #4
QuoteOriginally posted by irishwhite Quote
K series lenses had 52mm filter threads, later lenses, 49mm.
See: Pentax Close-up Accessories
05-18-2009, 10:20 AM   #5
Wheatfield's Avatar
They made reverse adaptors for both 52mm and 49mm for K mount.
05-18-2009, 11:02 AM   #6
irishwhite's Avatar
Okay, thanks guys! Guess i'll be sitting around waiting on a 49mm to go on sale.
05-18-2009, 11:10 AM   #7
Canada_Rockies's Avatar
You don't need to wait. Buy the 52mm adaptor and a 49>52 filter step up ring. With an M 28/3.5 reversed that gave me about 2.1X.
05-18-2009, 02:07 PM   #8
irishwhite's Avatar
Thank you sir....I've just now done that.
picked up the step up ring, reverse adapter, and also threw in some filters for the hell of it. :-)
adapter, camera, mm, pentax help, photography, reverse, thread
Reverse adapter question Jools Troubleshooting and Beginner Help 2 11-06-2009 04:11 PM
reverse lens adapter jolee1990 Troubleshooting and Beginner Help 4 09-09-2009 08:09 PM
*istD and Reverse Adapter K - problems. oldabelincoln Pentax DSLR Discussion 5 11-22-2006 11:50 PM
All times are GMT -7. The time now is 11:36 PM. | See also: NikonForums.com, part of our network of photo forums!
