05-20-2009, 03:24 AM   #1
new to pentax using K10D
i am practically new to the DSLR cameras and recently acquired a K10D, i was wondering if there is a macro mode available on the camera with out using a macro lense? please help.
05-20-2009, 03:30 AM   #2
Moderator Emeritus
The K10D, K20D and new K7 do not have a macro mode selection. But this mode in some cameras (like the K200D) only assist in exposure. They don't turn a normal lens into a Macro lens. You need to get a lens that can do close ups like the kit lens or a dedicated macro lens like the DFA100 or several other lenses.
You can adjust exposure just as easily in many of the modes on the K10D.
05-20-2009, 07:37 PM   #3
rfortson's Avatar
QuoteOriginally posted by Peter Zack Quote
<snip> But this mode in some cameras (like the K200D) only assist in exposure. <snip>
You mean there's a "macro mode" on the K2000? What in the world does it do? (Besides confuse people...)
05-20-2009, 08:16 PM   #4
QuoteOriginally posted by polokia Quote
No, you need a macro lens. The ability to do macro photography is a physical property of a lens.
05-20-2009, 08:35 PM   #5
1:1 Macro (or micro in Nikon parlance) means that a bug that's 5 mm across fills 5 mm of the film or sensor. This is achieved by a combination of focusing close and/or big focal length.
05-20-2009, 09:49 PM   #6
Marc Sabatella's Avatar
All that "macro mode" does on a typical P&S camera is tell the AF system that you'll probably want to focus close, so it doesn't waste its time trying to first focus far away. And when you're not in "macro mode", it similarly won't waste its time trying to focus close. Basically, it's just a way of speeding up AF by telling the camera in advance which half of the focus range to use.
Many - but not all - macro lenses for DSLR's have a similar switch (called a focus limiter). So if you have a lens capable of doing macro, you probably have a switch to do this. And if you don't have a lens capable of doing macro, such a switch wouldn't help.
On the other hand, a macro lens isn't the only way to get macro capabilities. You can also use a closeup adapter like the Raynox 150 or 250 in conjunction with an ordinary lens to allow it to focus more closely, as I did here:
And actually, the 18-55 that comes with most cameras can focus pretty close already. It doesn't have a focus limiter switch, but adding one wouldn't allow it to focus more closely - it would just prevent it from focusing closely when you didn't want it to. So to the extent that the kit lens can do something approaching macro, you don't need a special macro mode to allow this - just get as close as you can and shoot! Maximum magnification is obtained by setting zoom all the way to 55mm.
05-21-2009, 05:27 AM   #7
Marc,
That is an excellent explanation. Thanks for the clarifications as I, too, have wondered about this.
05-21-2009, 04:23 PM   #8
BTW, one other thing a macro mode might do is set the aperture small (high f-stop value) to give you lots of depth of field. But you don't need a "macro mode" for that, either - just use Av mode and set the high f-stop yourself - assuming you *want* large DOF.
05-21-2009, 09:21 PM   #9
res3567's Avatar
Hey Marc!
I ordered the Raynox 250 thanks to you and your insight. I also orderd the 49-43 step down ring per your suggestion.
I purchased a Quanteray 70-300 and it has a macro switch and like you said, it allows the lens to focus closer;
the switch in normal mode is actually the focus limiter.
In macro mode it allows the lens to turn more to the right. But it will only work in the 180-300 range.
Now that being said, what happens if I put the Raynox on the lens in its macro mode?
camera, k10d, macro, pentax help, photography
For Sale - Sold: Pentax K10D + Grip + OEM Pentax Battery + Remote F + Magic Lantern boox jjdgti Sold Items 4 11-04-2010 11:55 AM
Pentax Battery Grip BG2 for Pentax K10D, K20D Digital SLR's only $79 jacksonpritt Pentax Camera and Field Accessories 6 08-15-2009 08:19 PM
For Sale - Sold: Pentax LL-80 AF Divided Matte Focusing Screen for Pentax K10D MikeDubU Sold Items 1 02-11-2009 11:34 AM
For Sale - Sold: Pentax BG2 Battery Grip for Pentax K10D and K20D Paul Sold Items 4 06-10-2008 04:19 PM
New camera: Pentax K10D, Nikon D80, Canon 450D, Pentax K200D ??? go4java Photographic Technique 3 03-30-2008 05:36 PM
All times are GMT -7. The time now is 08:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
