05-23-2009, 04:14 PM   #1
shutter closed in sensor cleaning mode
I have the *ist Ds and have been very happy with it over the years. Recently I have found dust spots on images and am attempting to blow them off the CCD. I have put the camera in the 'sensor cleaning mode' and the mirror goes up but the shutter remains closed.
Should hte shutter be closed? How do I open it to get to teh CCD?
Any help would be welcome.
05-23-2009, 05:27 PM   #2
Mike Cash's Avatar
I don't want to insult your intelligence, but first let's make sure whether the shutter is really opening or not. Put the camera in "B" mode and with the lens removed look into the camera while you press the shutter button. Hold it down for a second. What you see will be the CCD.
If that is the same thing you see in sensor cleaning mode, then the shutter is opening.
If it is not, then there is indeed a problem with your camera.
05-23-2009, 11:12 PM   #3
Many thanks for the reply.
Have done what you suggested and the shutter is still down. I am fairly sure that what I am seeing is the shutter and not the CCD. Certainly does not look like the photos of the CCD that I have seen elsewere.
Apart from this the camera has no problems and functions fine.
05-25-2009, 08:49 AM   #4
Marc Sabatella's Avatar
Only thing I can suggest is to take it a camera shop where you can compare it to another camera, or see if you can take a picture of what you are seeing and post if here. Should be a simple matter for anyone who has seen the inside of a normal camera to compare with yours.
05-25-2009, 01:46 PM   #5
Dear Mike and Marc
After setting the camera on 'B' mode and pressing the shutter button for around the rth time the shutter finally released and there was the CCD.
Repeated the process, finally got the shutter open and was able to get the blower and dislodge the dust whilst holding the shutter button down. Nice clean shots now.
The shutter still remains firmly shut when using the proper 'sensor cleaning' funtion but this seems to be a 'work round' the present problem.
Apart from this problem the camera is fine and there are no signs of any other problems with the shutter.
Many thanks for your help, particularly to Mike since I did not know about the 'B' mode option and this got me most of the way there.
05-27-2009, 08:17 AM   #6
StarDust's Avatar
I would have the camera checked just in case this minor problem becomes a major problem later on.
05-27-2009, 11:00 AM   #7
AndrewG NY's Avatar
QuoteOriginally posted by boywithbeetles Quote
Glad it worked out for you but take care that you don't damage anything--you wouldn't want the mirror to snap shut while the nozzle of your blower is poking in there.
camera, ccd, mode, pentax help, photography, shutter
sensor cleaning Dags Pentax DSLR Discussion 12 12-30-2008 10:12 AM
sensor cleaning DanLoc78 Pentax DSLR Discussion 12 07-23-2008 12:47 AM
Sensor cleaning: Pec-Pads or Sensor Swabs gadgetnu Pentax Camera and Field Accessories 29 09-24-2007 10:52 AM
Sensor cleaning > Sensor Swab > void warranty? Twinky Pentax DSLR Discussion 2 07-28-2007 01:10 AM
Weird Sound of K100D (K10D 2?) in B/Sensor Cleaning Mode RiceHigh Pentax DSLR Discussion 13 01-05-2007 07:01 AM
All times are GMT -7. The time now is 05:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
