05-25-2009, 03:45 PM   #1
Help with images
Can someone please help me with these images? I can't figure out what happened. I think I had the camera on shutter speed priority. I would take 3/4 shots of same image, and two of the three would be like these??
PENTAX K10D  Photo
PENTAX K10D  Photo
PENTAX K10D  Photo
05-25-2009, 04:18 PM   #2
jmc7104's Avatar
Your ISO setting was 1600 1/15 sec shutter speed f5.6 @ 200mm radically overexposed regardless of any mode. Every thing in your view finder should have been blinking. jim
05-25-2009, 04:25 PM   #3
ctt
Thanks Jim, but why would it change in between my shots?
05-25-2009, 04:33 PM   #4
jmc7104's Avatar
Do you have your iso set toauto or were you possibly using tva mode otherwise camera shouldn't change the iso I never use 1600 iso unless it is very dark and I need to shoot at a high shutter speed. jim
05-25-2009, 04:38 PM   #5
Ash
Community Manager
Ash's Avatar
ctt, in varying light, settings bordering on overexposure will give unconsistent results. The one good shot you got would have just been because the available light was just dim enough to not overexpose your shots at ISO 1600.
I'd suggest you shoot in green mode if you're not sure what settings to have on.
05-25-2009, 04:38 PM   #6
ctt
I think in the shutter priority it doesn't matter what my camera setting is (which is 200), I would never use 1600 anyway. But, what is really wierd, is that in the next shots, everything is fine. I can't believe the light changed in just a few seconds. It's like when you are shooting with flash, and u shoot before the flash has time to charge----except of course I wasn't using a flash! Any ideas on why the shutter speed would change in a matter of a few seconds taking another shot?
05-25-2009, 04:39 PM   #7
Ole
Ole's Avatar
You had exposure compensation set to +2.5 stops overexposure and you got exactly that - overexposure! You could accidentally have held the EV button down while turning the front dial.
Set exposure compensation back to 0, set the ISO back to a more normal value like 100 or 200, and you should be fine!
05-25-2009, 04:41 PM   #8
ctt
Ash, thank you for ur response. I thougt working in shutter priority in this instance was good. I think when I shot the first image, the shutter speed was at a good number, then assumed my next shot would be at the same speed. Don't know why it would change in a matter of seconds, then change again after the 3rd shot!
05-25-2009, 04:43 PM   #9
ctt
Well that makes sense! Thanks Ole! So much to watch for, in so little time!!!
05-25-2009, 04:45 PM   #10
jmc7104's Avatar
I went back and checked your exif data on all 3 photo's and the only constant is the 1600 ISO Different shutter speeds for each shot, all definatly too slow for ISO settings, what I dont understand is 3 different ev comp settings and 3 different focal lengths. jim
05-25-2009, 04:49 PM   #11
ctt
Well Jmc, I'm glad I'm not the only one confused!!!! LOL
05-25-2009, 05:10 PM   #12
jmc7104's Avatar
Confusion
Hey I have been taking photo's since the 50's, first slr/35mm back in 57 and shot slides for next 25 years. Went digital in the late 90's with P&S and DSLR couple years ago. Still leave some special setting on camer occasionally and screw up a couple photo. I just blame it on oldtimers.
jim
05-25-2009, 05:11 PM   #13
You must have one dial set on EV comp and moved it between the pictures. Go to line 22 in Custom Settings. That should be your culprit.
edit: line 22 is for K20D. On K10D, it would be the 4th "page", line 4.
05-25-2009, 06:43 PM   #14
pbo
pbo's Avatar
Another thing - you used spot metering, and in all pics animals' black bodies were in the center. Check if your good picture has a black animal right in the center If not, that explains it.
05-29-2009, 07:56 AM   #15
AndrewG NY's Avatar
EXIF suggests lots of potential problems as already noted by some above. You're also using spot metering and auto-bracketing, both of which can contribute to big shot-to-shot variations if you're not careful.
camera, images, pentax help, photography
K-7 iso 3200 images: No NR, yet the faces look plastic. (11 images) pcarfan Pentax DSLR Discussion 43 08-31-2010 08:13 AM
How to see images vertical images after download as vertical ? netuser Troubleshooting and Beginner Help 8 08-28-2009 03:48 PM
A variety of images with FA* 200/4 Macro (no bugs) - VLF competition images Marc Langille Post Your Photos! 28 08-22-2008 07:28 PM
High ISO concert images with Tam 28-300 (Images) jsundin Post Your Photos! 2 07-05-2007 08:19 AM
A few K10D tourist images of Italy (9 images, about 200kb each) volosong Post Your Photos! 2 04-24-2007 04:29 AM
All times are GMT -7. The time now is 10:33 AM. | See also: NikonForums.com, part of our network of photo forums!
