05-26-2009, 04:27 PM   #1
Squier's Avatar
What have i done wrong..
I fitted an A lens for some shooting today, and i have the aperture ring set in the menu , which i did from day 1, but today, i cant seem to change the Ap with the E wheel anymore
Maybe i have accidently changed something without realising it, but what would it be ?
05-26-2009, 04:45 PM   #2
Check to make sure the lens aperture ring is firmly in the "A" position
05-26-2009, 04:47 PM   #3
Squier's Avatar
Check ..
Locked in nicely
05-26-2009, 05:58 PM   #4
Damn Brit
Guest
Try cleaning the contacts.
Do you have the battery grip, sometimes the switch on that can cause problems, it can get left between off and on.
05-26-2009, 09:58 PM   #5
Wheatfield's Avatar
QuoteOriginally posted by Damn Brit Quote
The focus selector switch can also cause this grief if it's between settings, as can the AF switch.
05-26-2009, 10:16 PM   #6
pbo
pbo's Avatar
Sounds stupid, but maybe you accidentally changed what function your e-dials are assigned to? Also, they might have different settings between Av, Tv, P, and etc. modes - check your custom settings. I usually set e-dials same way in all modes - rear for aperture, front for shutter speed, or else it gets confusing...
05-27-2009, 03:14 AM   #7
Squier's Avatar
Thanks all - checked everything you all said, and it may be contacts on the lens itself.
I swapped it over for one of my other A lenses, and everything is ok. Put this other A lens back on, and the ability to change Aps has disappeared again, so it must be the lens ?
I'll try cleaning the mating surface and contacts i guess
05-27-2009, 03:27 AM   #8
Squier's Avatar
Ok, cleaned contacts on the lens, but noticed that the 2 little " ball bearings " for want of a better word, that push down and spring up, seem to be sitting rather low. I think its actually level or even slightly below the mating surface.
Could this cause the problem ?
If it is, it means i have to remove the contact plate and push them back out ? There's 4 screws to do this, but would i have to remove anything else first ?
I dont like the look of this really
05-27-2009, 11:33 PM   #9
OregonJim's Avatar
QuoteOriginally posted by Squier Quote
The contacts should be sitting about 1mm above the mount surface. It's possible that the spring steel arms that hold them in place have gotten loose - you may be able to tighten them a little after removing the mount from the lens. It shouldn't be too difficult to fix, really.
05-28-2009, 03:41 AM   #10
Squier's Avatar
Well i've opened the lens up and 2 ittle bits fell out ! One of which was the button that locks the Ap ring in the A position. The other bit - havent a clue.
Put everything back together, and although the Ap ring no longer has a ' click ' as you pass each Ap number or a lock to keep it in the A position, it still works fine, but still no Electronic Ap adjustment within the camera.
The Ap ring is now one smooth movement like the focus ring, but its not a big deal. It all still works fine
05-28-2009, 07:01 AM   #11
vizjerei's Avatar
I remember I read something before where ppl say that there is a small sphere kinda thing in the AP ring, which it do the lock and 'click'. so maybe you miss that little piece there when u open the lens.
05-28-2009, 07:20 AM   #12
Squier's Avatar
yeah its gone somewhere - but no matter. The lens still works ok, just cant use Ap control within camera. Manual ap change only from now on.
Something has gone wrong with the 77! barondla Pentax SLR Lens Discussion 3 08-14-2010 09:25 AM
What's wrong with my A 28/2.8? Rense Pentax SLR Lens Discussion 5 01-10-2010 06:16 AM
Am I doing something wrong...? imwillb Pentax DSLR Discussion 3 12-10-2009 11:49 AM
What did I do wrong? Allan Photographic Technique 19 04-24-2008 01:37 PM
What's right and what's wrong? dws1117 Photo Critique 2 01-08-2008 09:13 PM
All times are GMT -7. The time now is 10:44 PM. | See also: NikonForums.com, part of our network of photo forums!
