05-30-2009, 05:25 PM   #1
about K200D shutter speed
why the shutter speed could not increase more than 1/180 sec when i have the built in flash on?
i have NiMH rechargable batt in it at he moment and manual lens attached..
thanks in advance
05-30-2009, 05:57 PM   #2
Ole
Ole's Avatar
That's due to the way the shutter is constructed. 1/180s is the fastest shutter speed possible with the built-in flash because 1/180s is the fastest speed where the shutter is fully open thus exposing the entire sensor when the flash fires.
At higher speeds the shutter is actually a slit that moves across the sensor and the entire sensor is not exposed at any point in time.
With some of the dedicated external Pentax flashes you can go higher (called high speed sync). In this mode the flash will send several bursts while the shutter slit travels across the sensor.
05-31-2009, 02:06 AM   #3
thanks for your explanation, Ole, i thought it was something wrong with my camera..
camera, pentax help, photography, shutter
Shutter speed on K-x CrabShadow Troubleshooting and Beginner Help 7 08-14-2010 06:46 AM
what shutter speed did i use? pete_pf Pentax SLR Lens Discussion 9 10-20-2009 01:45 PM
Shutter Speed comovartia Pentax DSLR Discussion 3 12-20-2008 10:38 AM
Shutter speed?! seymop Pentax DSLR Discussion 4 10-02-2007 07:28 PM
Shutter Speed? ryanmkk Pentax DSLR Discussion 4 11-15-2006 03:27 AM
All times are GMT -7. The time now is 11:33 AM. | See also: NikonForums.com, part of our network of photo forums!
