As far as I'm concerned, actually getting a DOF preview is not all that important to me - given that the viewfinder darkens, and it' not *100%* accurate anyhow (the focus screen alters things in some case), I'd just as soon take the picture and look at the LCD.
However, I consider DOF preview an indispensible feature on a Pentax DSLR anyhow, because it happens to be the only way to get the camera to display the meter reading with a manual exposure lens. You can press a button to get the camera to set an appropriate shutter speed for you, but I prefer actually *seeing* the meter reading in the viewfinder, and that only happens while doing a DOF preview.
Not an issue if you don't use manual lenses often, or if you're comfortable with the "semi-automatic" exposure mode of pressing a button to set shutter speed (eg, if you normally use Av mode with modern lenses). But for someone who really uses manual lenses and manual exposure modes a lot, a Pentax camera without DOF preview is pretty severely crippled. For other camera brands, there may be other issues; DOF preview may have nothing to do with metering. So what I'm saying only applies when comapring pentax DSLR's.
