06-13-2009, 09:20 AM   #1
M42 lens' & shake reduction
Need some help with an M42 55mm f1.8 on K100D. I have been successful in using the lens and getting the meter to operate. What I am having a problem with is SR. I do not get prompted for focal length and the SR item on the menu is grayed. Also, LCD info says SR is not "on" even though switch is on. Should I be able to use SR? What am I missing. Thanks in advance for your help.
06-13-2009, 10:05 AM   #2
Igilligan
Guest
QuoteOriginally posted by Big Bob Quote
If you have set the custom menu Page 3 'allow aperture ring' set to 2. Then when you turn on the camera with a manual lens it should ask for shake reduction focal length.
06-13-2009, 01:34 PM   #3
QuoteOriginally posted by Igilligan Quote
The "Allow aperture ring" has been set to 2 - permit. My understanding is that if it weren't set to 2, I would not be able to activate the shutter release. Since I have been taking pictures without problem, I clearly can activate the shutter release.
06-13-2009, 02:50 PM   #4
ftpaddict's Avatar
Does the EXIF give you any indication of the lens' focal length?
06-13-2009, 05:22 PM   #5
QuoteOriginally posted by ftpaddict Quote
Interestingly, on the m42 images there is no focal length line on the EXIF while the line shows after iso on all my other images.
06-13-2009, 06:33 PM   #6
k0og's Avatar
Bob,
My K100D Super works great with manual lenses, including M42 Takumars. I am prompted for the SR setting every time when I turn on the camera.
I suggest you try the following two things:
1. Make sure you have the "Using aperture ring" setting at "2" and saved. With the power turned off, remove the lens from your camera body. Then turn on the camera body with no lens attached and see if it prompts you for a focal length - it should do so.
2. If you can't get it to work, try the CUSTOM SETTING -> RESET CUSTOM FUNCTION menu item to reset your settings, then go back into the menu and set "Using aperture ring" back to "2" to allow manual lenses.
By the way, I also set "FI with S lens used" to "2" to give me the focus indicator. I have a Katz Eye focus screen, but the focus indicator is still sometimes useful.
Let us know what happens with these tests.
-Joe-
06-14-2009, 12:53 AM   #7
ftpaddict's Avatar
Or reset everything to default.
06-14-2009, 01:18 AM   #8
res3567's Avatar
QuoteOriginally posted by k0og Quote
Bob,
-Joe-
Pardon my ignorance, the K100D Super has interchangeble screens as well?
06-14-2009, 05:48 AM   #9
Thanks folks for your suggestions. Unfortunately the mystery continues. I took the lens off. I reset both the cust settings and the whole menu. Turned camera off and back on set Aperature setting back to permit. Turned camera off. Set SR switch to on. Turned camera back on - still no focal length prompt, still shows SR off in LCD. Nothing changed. I'm about to give up. The problem is not stopping me from taking nice images with the Tak, but it would be nice to have the SR feature available.
06-14-2009, 06:40 AM   #10
Mystery solved! I needed to set "FI with S lens used" to "available". Resolving this problem has re-confirmed to me 3 things:
1. The simplest things can trip you up.
2. When all else fails re-read the manual.
3. As others have noted many times, the folks on this forum are the greatest. Someone here is always willing to help.
Thanks,
Big Bob
06-14-2009, 06:43 AM   #11
k0og's Avatar
Bob,
Does SR ever work? For instance, with your kit lens and the SR switch to "on" does it work (try a very slow shutter speed like 1/2 second and you should hear it "buzzing" during exposure)? Try the dust-removal to see if it rattles when you implement it. Does the EXIF show the focal length with the kit lens?
It seems possible that the contacts on the SR switch are bad, but the SR test with the kit lens should tell you that.
-Joe-
06-14-2009, 06:49 AM   #12
k0og's Avatar
Excellent Bob!
I would not have thought that menu item would affect SR function. I've always had it turned on with my K100DS. I'll try without it right now...
Yep, sure enough that "FI with S lens used" must be set to "available" - since I've always liked having the focus indicator, I've never tried without until just now. I guess that menu item is the key one which tells the camera that there is an M42 lens mounted.
I'm glad to have learned something from this Bob, and glad your camera is in good shape!
-Joe-
Thanks,
Big Bob
camera, help, lens, m42, pentax help, photography, sr
m42 shake reduction Scott_the_Artist Troubleshooting and Beginner Help 3 09-10-2009 07:46 PM
Using long telephotos & Shake reduction mr.voigtlander Pentax DSLR Discussion 28 06-04-2009 11:56 PM
No shake reduction with M42? dbuffington Pentax SLR Lens Discussion 8 02-05-2009 06:24 AM
F series zoom lens & Shake Reduction calicojack Pentax SLR Lens Discussion 3 02-22-2008 08:25 AM
K10D, Shake Reduction & Tripod switch79 Pentax DSLR Discussion 28 04-19-2007 06:18 PM
All times are GMT -7. The time now is 11:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
