Originally posted by Jimdandy I read about fine tuning the white balance and whereas it is possible on the K200D, it's like you said just not realistic and you wouldn't have a guiding number to go by. You would need to try trial and error until you find a setting that might give the impression of stronger warmer tones.
Well, given that this stuff is all subjective, you'd be doing that with Nikon too. I mean, just because Scott happens to prefer Daylight -3, doesn't mean that would be your favorite, too.
Quote: If anyone ever hits on a value I.E. select Daylight then > Fine Tune A2 M1 for an example , please post it! Maybe a filter would be the best option, but that's another expense.
Like I said, it's extremely doubtful that we're talking about anything much different from just choosing one of the three WB settings I mentioned. try all three, decide which you like best, and you're done.
Quote: For some reason I'm not that fond of shooting in RAW, files are huge and most of the programs I use can't convert them anyway
Well, then you've got the wrong programs! Get something like Lightroom, Aperture, or ACDSee Pro and you'll find RAW so much simpler than whatever you're doing now with JPEG, you'll never go back. Here's a quick hint - if your software makes you convert at all, you want something better that doesn't force you to convert everything.
As for file sizes, on the K200D using PEF, I find file sizes "only" around twice as big as JPEG - not a *huge* deal compared to earlier cameras that didn't compress their PEF files, making them much larger.
Quote: So that just leaves me with the Silky Pic program and about all I do with it is to convert them to jpeg anyway.
If you mean the Pentax software, yeah, that's enough to put anyone off RAW. But if you have the "real" silky pix, you might play around with some more - it's capable of far more than you are using it for.
