Originally posted by Quension You can reset the file number in the Record menu, Memory -> File No., although you'll have to change it back afterward to keep a sequential count. See page 213 in the manual.
Hi, thanks for the post. I didn't make the link between the number and the folder. That's kind of where I was going, although it still means you don't know exactly how many actuations your camera has taken.
It is interesting that you may set the folder to the date, and record from image zero on that date. I wish there was calendar view support in camera like other brands - I still use the TV to display to family every now and again.
@vk4akp - If you set the folder to PENTX (in setup tab of the menu), and click on the check box of the File no. in the Record menu tab (under memory), then the numbering should continue to increment upwards with whichever card you place into the camera.
