06-30-2009, 08:53 PM   #1
fccwpe's Avatar
Macro Extension Tubes
Maybe I made a mistake.... I bought some generic extension tubes for real cheap. I guess I didn't do enough research, though because I don't think they provide any electrical connection from lens to camera. Here's the problem, I only have one lens with an aperture ring (Tamron 70-300 ). Can I use it with the SMC DA 16-45? Is there a way to use the tubes with a lens without an aperture ring?
Hmmmmm.... glad I didn't pay too much.
06-30-2009, 10:08 PM   #2
Damn Brit
Guest
You can use a lens without an aperture ring but only at the aperture it is fixed at when off the camera which is going to be the smallest that the lens can go to.
Get yourself an old MF 50mm lens to use with the extension tubes. You need to MF anyway and it will have an aperture ring.
06-30-2009, 10:13 PM   #3
imtheguy's Avatar
Just for fun I tried taking a macro shot just now with my 16-45mm and a contact-less tube. Had to use bulb mode and with the aperture at 22 trying to find a focus was not fun. No, there was no fun in using that combo. Go back to your lens with a ring.
06-30-2009, 10:15 PM   #4
Damn Brit
Guest
QuoteOriginally posted by imtheguy Quote
He didn't ask if it was fun, just if it could be done.
OP, the extension tubes you have aren't the problem, it's the lenses you have available. A cheap MF prime will be the best solution for you.
06-30-2009, 10:18 PM   #5
octavmandru's Avatar
Or buy an old lens like a K/M42, 28 mm, an adaptor for reversing the lens.... And then you'll see some nice results.
07-01-2009, 10:36 AM   #6
fccwpe's Avatar
Thanks for the help! I guess I'll be looking into a fully manual lens of some sort (50mm or so)
Thanks again!!
07-02-2009, 05:23 AM   #7
jmc7104's Avatar
QuoteOriginally posted by octavmandru Quote
Even better buy any old cheap brand of lens and get matching reversing ring and use it only for macro. I have a varity of non K-mount lenses that I plan to do this with. jim
07-04-2009, 09:07 AM   #8
I also highly recommend an old Pentax M 50mm lens. I picked up a dandy 50mm f/1.4 on Ebay for $30, and used that with extension tubes (and occasionally a reversing ring) for quite a while--until I found a even dandier Pentax M 100mm dental Macro lens for $100 on the site classifieds here.
Watch out, macro is an addiction! Now I have ring lights, teleconverters, piggyback adaptors, focusing stage, a brand new ring flash.....all for shooting only the occasional fly fishing entomology article.
DAN
aperture, camera, extension, lens, pentax help, photography, tubes
Question about using extension tubes for macro uchinakuri Pentax SLR Lens Discussion 17 06-09-2010 03:00 PM
Macro Cheapo Macro Extension Tubes JimD_K10D Post Your Photos! 3 09-26-2009 04:55 PM
Macro Extension Tubes Rondec Troubleshooting and Beginner Help 8 04-13-2009 09:40 AM
Macro Extension Tubes gr8wings Troubleshooting and Beginner Help 13 02-06-2009 02:11 PM
1:1 Macro with extension tubes hinman Pentax SLR Lens Discussion 10 07-29-2008 02:50 PM
All times are GMT -7. The time now is 07:33 AM. | See also: NikonForums.com, part of our network of photo forums!
