07-01-2009, 06:33 PM   #1
K20D viewfinder accuracy help
i recently picked up a K20D body, and i noticed that the shot i take versus what i see in the viewfinder is a bit inaccurate.
example: if i take a photo of a soda can and i intentionally want the top of the can clipped, but when i take the shot, the photo shows the can without any clipping.
my K100D does not do this, so i'm assuming there's something wrong with the K20D.
is this something we could calibrate ourselves, or am i better off exchanging it for another?
07-01-2009, 06:40 PM   #2
pbo
pbo's Avatar
The viewfinder's coverage is less than 100%, so what you get is actually not what you see, but a little bit larger area of what you see.
On K20D, area covered by viewfinder is 95%, on K100D it's 96%, and there's no way of calibrating that. Exchanging probably wouldn't give you better results, either.
07-01-2009, 07:01 PM   #3
i see. thanks for the info. (did i post my question in the right forum?)
07-01-2009, 07:11 PM   #4
pbo
pbo's Avatar
no problem, and you did post in the right forum (I think).
07-01-2009, 08:49 PM   #5
Damn Brit
Guest
Yeah, you posted in the right forum
Welcome.
07-01-2009, 10:01 PM   #6
mikeSF's Avatar
for me, more often than not, this little "discrepancy" has been a blessed relief. it is forgiving if i frame the shot a little too tightly or fail to notice a part of the subject that hangs off the edge of my shot, etc. later, in reviewing my RAW shots, i've often been able to use that extra little sliver of image around the perimeter.
YMMV.
07-03-2009, 05:51 AM   #7
Try This.......
The Pentax viewfinder magnifier should give you a more accurate view. That is ,of course, if your viewfinder shows less than the picture produced. I bought one for close-ups but I've left it on the camera (K200d) permanently.
07-03-2009, 07:00 AM   #8
WheresWaldo's Avatar
QuoteOriginally posted by Daveinozbikes Quote
This accessory, while never leaving my camera does not change the % of view of the viewfinder. I can make manual focusing more accurate for some.
07-04-2009, 04:54 AM   #9
Sorry WheresWaldo...I have to disagree..it brings the subject 20% closer in the viewfinder thereby enlarging it. Look at your PC screen on wide angle and take the edges of the screen to the edges of the viewfinder. Take the magnifier off and look again from the same spot. The screen is smaller (Not much but 20% ain"t much...)
07-04-2009, 05:29 AM   #10
It doesn't improve accuracy. It can't add to the viewfinder the part that's not in. It enlarges what you see, and that's all. The viewfinder shows only 95% of what the sensor will record, and nothing will change that.
07-04-2009, 06:00 AM   #11
mattdm's Avatar
Except, it must be pointed out, buying a K-7, which features a 100% viewfinder.
07-04-2009, 06:26 AM   #12
QuoteOriginally posted by mattdm Quote
I should have it on Monday. Why are week ends so long?
07-04-2009, 06:46 AM   #13
Wow, this is so wrong on so many counts. The OP complained that the viewfinder does not show the entire scene, you suggested the magnifier, but it doesn't work for what the OP asked about. If you have 95% coverage with a viewfinder and you magnify it, you have an enlarged version of 95%, that's it, end of story.
See flyer's comment too!
camera, k20d, pentax help, photo, photography, shot, viewfinder
AF accuracy: k-7 vs k20D augieviking Pentax DSLR Discussion 1 08-01-2009 07:18 PM
K200D viewfinder + Katzeye VS. K20D viewfinder dugrant153 Pentax DSLR Discussion 3 07-24-2009 11:36 AM
K20D AF.C Accuracy Nanthiel Pentax DSLR Discussion 6 09-14-2008 10:13 PM
K20D exposure metering accuracy Andrews Pentax DSLR Discussion 3 05-18-2008 07:18 AM
K20D vs K10D: WB colour accuracy creampuff Pentax DSLR Discussion 4 03-04-2008 10:53 AM
All times are GMT -7. The time now is 03:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
