07-04-2009, 05:34 PM   #1
A few ?? about my Pentax ME
Hi all,
I bought a Pentax ME way back in 1977 and have dug it out after decades of storage and want to get into learning how to use it. I got it all cleaned and serviced but I don't know jack about photography so I have a few newbie questions if you don't mind. First it has a SMC Pentax-M 1:1.4 50mm lens. What size lens cap do I need for it? A 49mm or a 52 as I can't find any for 50mm. Second, what would be a good telephoto lens to get for nature shots? I have a tripod for it. I know I'll have more questions later (get ready as I have a Pentax Stereo Adapter for it also that I bought at the time). Thanks for your time and help.
Mike
07-04-2009, 05:56 PM   #2
Andi Lo's Avatar
Mike, when it says 50mm on the lens, that's the focal length, not the lens cap size. Sometimes lens cap size would be shown after a Φ symbol, but I don't think that's the case with the M 50/1.4. Annnd to answer your question that lens needs 49mm cap, as with most of pentax's lenses under 135mm. If you're not in a hurry dealextreme have caps for cheap, otherwise I do suggest supporting local shops.
For telephoto with that body an M135/3.5 or M200/4 would be great. If you want a zoom the M80-200/4.5 might be a good choice.
Pentax Telephoto Prime Lenses
You can still use lenses from other generations as well and use all the features supported by the ME (other than DA and FA-J), I just mentioned those three because they are perfectly functional with your ME (from the same generation), good performers, and relatively cheap.
07-05-2009, 07:05 AM   #3
Than you very much Andi. I have a lot to learn here as I thought a telephoto and zoom were the same thing! Oops! Time for me to get studying. I'll check out those lenses you've mentioned.
Mike
50mm, camera, lens, pentax, pentax help, photography, questions, time
All times are GMT -7. The time now is 03:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
