07-11-2009, 11:40 PM   #31
Paul MaudDib's Avatar
QuoteOriginally posted by Graham67 Quote
I'd had 35mm film compacts (Pentax & Yashica), then a (digital) Compact (but decently manual) Canon A80, then an A95, then a Lumix FZ18 (digital bridge/superzoom).
Heh, indirect response to the OP here. I totally advocate playing around with a K1000 or similar full-manual TTL metered SLR. You can directly see the effect your actions take on the light meter. It really made learning a lot easier for me at least. I played with a point and shoot for years but an SLR was a lot different. Honestly I don't care about the film aspect. What I really like is having completely external controls that I don't need to plow through menus to get through. The green button and thumbwheel is okay I guess but I really prefer having actual controls. It doesn't even look like his lens has an aperture ring and I think this is just how lenses are nowadays.
A camera with an aperture-priority mode like the ME Super is better for actual shooting and the K1000 has been run up in prices a lot recently since it was discontinued (but schools certainly didn't discontinue using it!). It's probably a better buy if you want to play around.
07-13-2009, 11:00 PM   #32
res3567's Avatar
QuoteOriginally posted by impact Quote
First thing I did was:
- change file type to JPEG+RAW
- select single AF point (the middle one)
- change JPEG profile to the 2nd one (the "normal" one with muted colors)
Anyways, this was one of my first shots with the K-m (the cat was intriuged by the new toy and the strange noise from the AF motor ):
But what I really want to know is where'd you get that nice case for the K-m/2000 and how does it fit? I got the neoprene case and don't like it, it's very tight. By very tight I mean I really have to force the camera inside with no room to spare (I bought and put a Hoya UV filter on the lens, perhaps that is the problem?).
Look at them teeth!
I LOVE THAT PHOTO!!!!
Oh sorry. Didn't mean to yell.
I LOVE cats........!!!!!!!!!!!
07-13-2009, 11:05 PM   #33
res3567's Avatar
QuoteOriginally posted by Paul MaudDib Quote
Congrats on your first dSLR! I still haven't gotten one yet.
With regard to shutter speeds: In short it's how long the picture is exposed. If this is longer, your picture will be brighter. The tradeoff is that your exposure is longer! If you are shooting something that's fast, it will blur. If you go below roughly 1/60th of a second, your photo will probably blur just from the shake in your hand, at which point you will need a tripod to do longer exposures. Faster action needs a faster shutter - running kids or shooting sports will need a short exposure.
Aperture: This is basically how far open the lens is. A perfect lens would be a pinhole, infinitely small. This lens could focus everything at once. This can't actually exist, so the closest thing is fully stopped down, which can focus most things. This is a very dark picture. The opening is measured in f-stops. I'm not sure how it works for dSLRs but for film lenses the smallest is usually f/16, f/22, or f/32. The tradeoff here is depth of field, how much is in focus, for light. Also, lenses are not at their best either fully stopped down or fully open. Keep them in the middle of their range for the sharpest and best picture, or open them up all the way to soften the picture (careful with the focus though!).
ISO speed: This is the "sensitivity" of the sensor/film. It's how much light it needs to expose the same amount of data. An ISO 800 film can expose twice as much in the same time as an ISO 400 film, and 4x as much as an ISO 200 film. The tradeoff here is grain. Film used to get grainy, and sensors do too. It will show up as light/dark spots in your image, google "ISO noise". You should be good up to ISO 800, 1600 will have moderate grain, and it gets worse from there.
To tie this all together: everything actually revolves around f-stops. Each exposure notch doubling the time doubles your light, this is 1 f-stop. For example, going from 1/250th of a second to 1/125th of a second gives you one f-stop increase in light. Opening your aperture one full stop gives you one f-stop. Doubling your ISO gives you an f-stop.
Now, basically you play a balancing game. You have a certain amount of f-stops to "spend". You can slow your shutter and try to have a wider depth of field, or try to use a slower ISO to get finer detail. You can increase your ISO to try and get a wider field of focus or a faster shutter. You can open your aperture to try and speed up your shutter or use a slower ISO.
Now, to make this still more complicated, if you save your RAWs (which you are, ) you can post-process and try to change things even more. You can do what's called "pushing" or "pulling". In film terms, this is shooting a film at the wrong exposure and under or over developing the film. You can push a picture and increase the brightness, possibly making the picture look right or getting extra detail in the shadows, at the expense of possibly "blowing" the bright areas. You can "pull" a shot and try to get extra detail out of the bright areas, darkening the picture and possibly losing detail in the dark areas. You can sort of do this in the camera by using the EV controls too, and I think this is supposed to be better, but obviously must be done in real time.
Someone tell me if I'm wrong on any of this, but I think it's a good place to start.
Dude!
You have a ton of knowledge and you aint got no DSLR?
You are ready for one for sure!
camera, dslr, pentax help, photography, time, tomorrow
Greetings from a first time DSLR owner Avilion Welcomes and Introductions 3 05-01-2010 08:16 PM
First time w/ my dSLR mrwizardgi Post Your Photos! 5 12-16-2008 05:30 PM
First time with DSLR VenomXTF Post Your Photos! 7 08-12-2008 06:05 AM
First time DSLR ownder from TN Meredith Welcomes and Introductions 2 05-31-2008 09:50 PM
First time with a dSLR CJCram Post Your Photos! 9 09-25-2007 02:16 PM
All times are GMT -7. The time now is 12:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
