07-07-2009, 03:47 PM   #16
I primarily shoot Av but when I do sports stuff, I'll often drop into Tv so that I can maintain a certain level of motion blur to emphasize the action a bit. Honestly, it all depends on what you are trying to achieve (use of aperture & shutter settings).
Like the other folks said, it's best to do a little homework and test, test, test so you are comfortable know which to use when.
Cheers.
07-07-2009, 03:56 PM   #17
octavmandru's Avatar
QuoteOriginally posted by vmax84 Quote
I guess my thinking on the depth of field, and why I shoot in Tv mode is if I want a large depth of field, I shoot a slow shutter speed.......if I want a narrow depth of field, I shoot at a higher shutter speed.
Yeah, I know.......go do some reading and hands on with the camera. :-) I guess there are worse things to do with a little bit of ones spare time, huh?!!
vmax84
Hey! That's an interesting approach. And not the wong one vmax.
Many have complained about HyP way of switching Tv-Av. Now this is giving me the ideea why this was engineered like it is (with limitations).
My advice is: learn it your way, and learn it good.
And do some reading in the meantime, experimenting...
07-07-2009, 11:22 PM   #18
Marc Sabatella's Avatar
OK, but what shutter speed do you need to get a particular DOF? It's basically trial & error and/or guessing. With Av mode, if you know the aperture you need to get the desired DOF, you can dial it in directly. Also, what happens when the light changes? With Tv mode, you need to chage shutter speed just to keep the same aperture. It's a really odd, indirect, and ultimately inaccurate way of controlling DOF.
Not that Tv mode wouldn't have its uses for other purposes. But using it to control DOF is a very awkward and error-prone way to do it.
07-08-2009, 02:52 AM   #19
I am right handed............I feel like I have to re-learn how to write and write left handed now!!!!
vmax84
07-08-2009, 06:09 AM   #20
heliphoto's Avatar
vmax84
Keep in mind that for the same picture, whether you use Tv and dial shutter speed until you see your desired aperture appear, or use Av and set aperture directly, (letting the camera set shutter speed as it sees fit), shutter speed and aperture will be exactly the same for the same shot - the light is the same and therefore the exposure settings will work out the same regardless of how they're derived.
07-08-2009, 06:02 PM   #21
" guess my thinking on the depth of field, and why I shoot in Tv mode is if I want a large depth of field, I shoot a slow shutter speed.......if I want a narrow depth of field, I shoot at a higher shutter speed.
vmax84"
If you are thinking of the important factor being DOF then select the aperture first and then decide whether the shutter speed id adequate for the circumstances.
For best compromise in setup menu set PROGRAM LINE to MTF.
The camera will read the lens data from the lens and set for best compromise possible in the existing lighting.
Do your own tests. Keep notes on what you do. That is the best way to learn.
Ron McDermott
aperture, blur, camera, care, depth, diet, field, light, pentax help, photography, picture, shutter
Obama's health care law will increase the nation's health care costs Artesian General Talk 187 05-20-2010 10:18 AM
Streets Does He Care? hockmasm Photo Critique 8 05-18-2010 11:47 PM
Health Care for Everyone... NOT!!!! Fl_Gulfer General Talk 235 12-17-2009 06:40 AM
How we are going to do this? Health Care Russell-Evans General Talk 196 09-22-2009 06:23 PM
Take care Oz eBay Buyers wwwmorrell General Talk 16 04-12-2009 11:32 PM
All times are GMT -7. The time now is 12:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
