07-08-2009, 03:17 PM   #1
Storing Camera/Lenses
Do you take any type of precaution when putting your camera away for the day?
I mean I am paranoid of dust on my equipment so whats the best practice when trying to expose your equipment to the least amount of dust possible during non use?
07-08-2009, 05:23 PM   #2
Wheatfield's Avatar
I try to remember to put lens caps on and zip the case up so that my dogs can't use my equipment as chew toys (my Rottie really likes one of my lens cases).
Where you are, I'd be more concerned about mold than dust.
07-08-2009, 06:19 PM   #3
what about a dry box? worth it?
07-08-2009, 06:25 PM   #4
wlachan's Avatar
I put them in plastic dry box with moisture absorber. There are also electric dry cabins being offered from Japan, Taiwan & China and they are quite popular in asia. But depends on how many gears you have, you might just zip them in plastic bag with moisture absorbers.
07-09-2009, 05:10 AM   #5
QuoteOriginally posted by NothingInCommon Quote
Store it in an incubator in a clean room. Or stop worrying too much about dust...
07-09-2009, 05:20 AM   #6
moisture absorber storing
QuoteOriginally posted by wlachan Quote
Where do you get the moisture absorbers? Do you use things like the Silcia(?) packets found in shoe boxes? I have been trying to put my gear in a dry bag with these but can find a company that sells them. Any ideas?
07-09-2009, 05:28 AM   #7
Here's a link to ebay for silica gel desiccant packets: silica gel, great deals on Cameras Photo, Business Industrial on eBay!
Put one in a ziplock bag with your gear.
Dave in Iowa
07-10-2009, 01:50 PM   #8
GerryL's Avatar
QuoteOriginally posted by liberiabound Quote
You can actually use those but you have to dry them out in the sun once in a while to recondition them or dry out the humidity (moisture) that they already absorbed so they can absorb more.
There is an ideal RH (relative humidity) that must be maintained if you decide to use a drybox or make yourself one 'coz if the RH maintained is too dry, the rubber gaskets or such may crack on your equipment.
07-10-2009, 02:00 PM   #9
TaoMaas's Avatar
If you're concerned about the humidity level in your house, you might try hitting a few garage sales, estate sales, or flea markets. It used to be really popular for folks to display a set of guages that usually consisted of a thermometer, a barometer, and a hygrometer. I found one at an estate sale for $1.50. It won't solve your humidity problems, but at least you'll have an inexpensive way of knowing where you stand.
07-10-2009, 09:54 PM   #10
Ratmagiclady's Avatar
If you only have the one camera and lens, the best maintenace in this way is to *use* it. Do not try to go to extremes unless you know how to do it right. If you over-protect something, and botch it, you're as likely to be sealing moisture and mold in its ideal damp environment as to be protecting anything. An ordinary camera bag bag, not-tightly sealed, in a reasonably-climate-controlled space is going to be one of the best things you can do.
If you have a *lot* of stuff, some of which might tend to be shut away in the dark for long periods, that's when you want to take a lot of care. If you close something up in a Southern clime and aren't assiduous about maintenance, you could do more harm than good: dessicants basically turn into sponges: once past their capacity, they'll actually release moisture in bad ways if the space is locked up too tightly, and that's a breeding ground for molds.
If in doubt, take nothing to extremes.
As for dust, just use common sense. Simply don't be so afraid of it that you end up trapping moisture. It'll be OK.
07-10-2009, 10:04 PM   #11
LeDave's Avatar
Sweet, after reading this I went to take the silicon packet out of my K-M/K2000 box and place it inside my Pentax Holster bag.
07-10-2009, 10:15 PM   #12
QuoteOriginally posted by LeDave Quote
Just do dry or swap them out periodically. They *will* absorb more than they can hold if it gets really damp. Then they turn from your friend to constant source of not-dry.
Also, do not eat them. Tempting, I know.
(I actually use reuseable aluminum ones meant for gun-safes in my not-very-airtight gear storage cabinets. But over years when I had little, I just kept what I had in a couple of bags in living space. )
Oh, also. Old trick. Cloth bags of Minute Rice. But pitch them on return from any time they're exposed to a rainy day. Same principle as the silica gel, but much quicker on the time frame before they get counterproductive.
07-11-2009, 08:06 AM   #13
joebob's Avatar
I think you can get small containers of moisture absorber from Walmart. They're mostly used in closets or damp spaces. You just drain out the water when they get full.
07-11-2009, 05:43 PM   #14
GerryL's Avatar
QuoteOriginally posted by joebob Quote
Your house must be really damp if you have to drain the thing of water!
07-11-2009, 08:58 PM   #15
Duck Dodgers's Avatar
I bought a pair of cans of silica from Cambridge or Spiratone back in the day. They still work. Pop them in a 200 degree oven when the window turns pink.
Pelican | Silica Gel | PC1500D | B&H Photo Video
camera, dust, equipment, pentax help, photography
Storing your lenses HawaiianOnline Pentax SLR Lens Discussion 20 03-20-2014 06:45 PM
Storing lenses up or down? Kguru Pentax SLR Lens Discussion 40 08-18-2009 10:58 PM
storing in camera bag houstonmacgregor Pentax Camera and Field Accessories 4 07-23-2008 10:07 PM
Storing Lens on the Camera? Joe_M Pentax DSLR Discussion 8 01-03-2008 06:47 PM
Storing Your Camera TakeshiKovacs Pentax DSLR Discussion 9 12-28-2007 06:48 AM
All times are GMT -7. The time now is 12:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
