07-12-2009, 10:00 AM   #1
CPL as a ND?
Will a CPL reduce the amount of incoming light when shooting toward the sun, for example sunrises and sunsets.
Or is it constructed in such a way that it only cuts the amount of incoming light when the sun is at a ninety degree angle?
I know it reduces glare and the washing out of colors at ninety degrees to the sun, but what about light in general at any angle? Or does it vary by the angle?
Thank you for any response.
Jim
07-12-2009, 01:09 PM   #2
Marc Langille's Avatar
Hi Jim,
Believe me, a CPL reduces the light - about 2 stops. I pretty much have one on my 12-24 all the time. It's only removed when lighting or other conditions warrant it.
That doesn't mean you cannot consider an ND filter. I am just giving you my example/situation. The CPL is one of my favorite filters.
Regards,
Marc
07-13-2009, 10:43 AM   #3
Like Marc said, yes, you can use one as a ND. However one word of warning, a CPL is not necessarily neutral. By that I mean you can't stack them with impunity. I once forgot my ND filters and wanted to take some slow moving water shots. So I stacked two PLs together. I got the light reduction I wanted but totally confused the poor DS's WB. I was getting electric blue shots and stuff that looked like it had been shot thru some sort of weird red lens, but nothing even remotely "normal".
NaCl(I thought I was about 40 years younger and "grooving on the colors man")H2O
amount, angle, camera, cpl, light, pentax help, photography, sun
Landscape With and without a CPL Jimbo Post Your Photos! 4 12-11-2009 04:15 PM
Question about CPL/UV jerrymouse Pentax Camera and Field Accessories 5 06-17-2009 07:45 PM
Help me choose a CPL - what should I get? Gadget_Guy Pentax Camera and Field Accessories 8 07-02-2008 06:43 AM
Using CPL on Sigma 10-20? Cokin CPL? PeterAM Pentax Camera and Field Accessories 8 05-19-2008 04:24 AM
CPL or LPL ? axl Pentax DSLR Discussion 9 12-14-2007 11:23 PM
All times are GMT -7. The time now is 09:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
