07-13-2009, 11:09 PM   #1
K-7 strange not nice sound during starting up...
Hi,
can anybody hear a short unpleasant sound, when you turn on your camera?
Similar to checking DOF in K10D/K20D.
The reason, that I discovered, is this small aperture lever inside the camera, which very quickly shakes up and down....
Is that normal?
07-13-2009, 11:10 PM   #2
Damn Brit
Guest
It's the dust removal.
07-13-2009, 11:20 PM   #3
heliphoto's Avatar
QuoteOriginally posted by Damn Brit Quote
It's the shake reduction.
Eh? Gary this sound like crazy talk mate...
Is it possible you've activated a dust removal on startup option? I've reading this sounds like a buzzing on startup vs. the old rapid clunking sound of the older models with the dust removal feature.
Edit: if you're seeing the aperture actuation lever shaking on startup, that would be weird, but I don't have my k7 yet so I can't say for sure.
07-13-2009, 11:24 PM   #4
Damn Brit
Guest
QuoteOriginally posted by heliphoto Quote
Oops! You know what it's like with a new baby Josh.
I've corrected my post, I knew what I meant.
07-13-2009, 11:30 PM   #5
No, this is definetely NOT the dust removal. The dust removal in K-7 is nearly soundless, however you can hear a very high tone from the inside of the camera.
Yes, I can see it. That's why I'm asking K-7 owners.
07-13-2009, 11:31 PM   #6
Damn Brit
Guest
QuoteOriginally posted by Samp Quote
I made a booboo, see above.
07-13-2009, 11:47 PM   #7
BTW, I'm not the Pentax Beginner....
I use Pentax since 1998, I own ME Super, MZ-3, i also owned MZ-6, K10D and K20D... I really know what I'm writing about.
Here I found a post describing similar problem:
http://forums.dpreview.com/forums/read.asp?forum=1036&message=32353530
07-14-2009, 03:10 AM   #8
Christopher M.W.T's Avatar
I heard it to, then realised its the ultrasonic dust cleaner....trust me, ultrasonic ie HIGH frequency!
07-14-2009, 03:42 AM   #9
It's NOT the dust cleaning, dust cleaning sound is AFTER that strange one – it's a specific high frequency whistle. I recognize it.
I'm afraid somethings wrong with the ON/OFF switch. It simply tries to check DOF, each time when its being turned on. Also when camera goes to "sleep mode" and wakes up, the same event appears.
07-14-2009, 08:10 AM   #10
Dr_who's Avatar
I did the dust removal option when the lens was off and it does get pretty high when you do that.
07-14-2009, 08:45 AM   #11
GLXLR's Avatar
Hi,
Is that normal?
Make a video so we can hear/see it. Might help you get a better answer.
07-14-2009, 08:59 AM   #12
theres a thread about the same "problem" in a german forum.
it really is the aperure lever. if you have a lens on while turning the k7 on, the aperture of the lens opens and closes, too.
the OP asked pentax about this behaviour and they replied, that it would be normal and part of the new way how the aperture is controlled (somehow electronically instead of mechanical). this is needed because of the aperture control in video mode.
07-14-2009, 11:28 AM   #13
OK, I checked another K-7 in the nearby store and it behaves in similar way.
Moreover, I discovered that changing the aperture in LV or Movie mode causes the same sound. It's not related to SRII, it's simply just the aperture lever inside the body.
So, there's nothing to worry about, however this sound is quite unpleasant.
07-14-2009, 11:36 AM   #14
GLXLR's Avatar
The aperture level is a high pitched sound? For my GX-10 (K10D) it sounds more like a tiny *clunk*.
Either way, I don't think it is a big problem, but if it bothers you, go check ANOTHER store and/or exchange for another K-7. Not worth it if it's going to bother you (like my loose 50-135mm focus ring)
07-14-2009, 11:51 AM   #15
Ratmagiclady's Avatar
Thought: People have different abilities to hear high-frequency sounds, ...I wonder if those who are hearing it happen to be the youngest.
camera, pentax help, photography, sound
Best starting lens? Cheap body and nice lens? or nice body and okay lens? lovemehate Troubleshooting and Beginner Help 52 10-12-2010 07:27 PM
Landscape nice house... nice boat.... dcmsox2004 Post Your Photos! 7 08-18-2010 02:49 PM
Nice... real nice SCOTUS jeffkrol General Talk 45 04-22-2010 08:41 AM
K-m (K2000) strange shutter sound wicked Shimmy Pentax DSLR Discussion 4 12-11-2009 03:44 PM
This might sound strange photolady95 Photographic Technique 26 09-30-2009 07:47 PM
All times are GMT -7. The time now is 02:48 PM. | See also: NikonForums.com, part of our network of photo forums!
